I Can't See All My Gauges!
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Rich H
PostPosted: Thu Oct 15, 2009 5:36 am    Post subject: Reply with quote
Pity, I'd have posted you one of mine, CPC are 20 mins away.
Ah well.
9XX Girl!
PostPosted: Thu Oct 15, 2009 6:15 am    Post subject: Reply with quote
Don't forget to post a diagram of your circuit
Scan a hand drawing or use Microsoft Paint
924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY
Rich H
PostPosted: Thu Oct 15, 2009 6:53 am    Post subject: Reply with quote
Not got that far yet....
9XX Girl!
PostPosted: Sun Oct 18, 2009 5:10 am    Post subject: Reply with quote
OK thinking of using this as my circuit design
This circuit is designed to test phototransistors with an analog meter without causing any additional current drain and volt drop.
The two 9v batteries will be replaced by a 7805 regulator.
R1 will be replaced by a trim pot.
The two arrow that indicate test leads for thephototransistor circuit will be the "ground" and "hot " connections on the MAP sensor
The Map Sensor will also be powered by the 7805 regulator.
Full info here http://home.cogeco.ca/~rpaisley4/xHiZmeter.html
9XX Girl!
PostPosted: Sun Oct 18, 2009 6:04 am    Post subject: Reply with quote
Like this
Rich H
PostPosted: Sun Oct 18, 2009 6:38 am    Post subject: Reply with quote
No need for the diodes there, I'd use a unidirectional suppression diode to clamp the incoming voltage to 18v or under but even then the voltage reg will sort anything up to about 40V.
I would also put a resistor in the line form the amp out and amp - to give a bit of damping. Taht will respond instantly (Pretty much) a resistor will give a tiny ramp up.
Not started mine as my gauge hasn't turned up and I'm re-looming my electric mirrors!
9XX Girl!
PostPosted: Sun Oct 18, 2009 6:53 am    Post subject: Reply with quote
You mean like this. What value R2 or what about a trim pot?
Rich H
PostPosted: Sun Oct 18, 2009 7:17 am    Post subject: Reply with quote
Left a bit...
I found these helped:
http://www.allaboutcircuits.com/vol_3/chpt_8/index.html
Instrument amplifier
http://sub.allaboutcircuits.com/images/03046.png
(All R the same R gain varies the overall gain of the circuit.)
9XX Girl!
PostPosted: Sun Oct 18, 2009 7:52 am    Post subject: Reply with quote
Rich H wrote:
Left a bit...
Left a bit ?????
Hmm, I will have a read. Thanx.
My MAP sensor hasn't arrived yet, op amps have though.
PostPosted: Sun Oct 18, 2009 8:03 am    Post subject: Reply with quote
Try this:
9XX Girl!
PostPosted: Sun Oct 18, 2009 8:11 am    Post subject: Reply with quote
Ok
I will
Thanx RC, knew i wasn't too far out. will start prototype board so that when Map arrives i can give it a go. I got enough components now to make ti all again nice and neat if it works OK.
9XX Girl!
PostPosted: Fri Oct 23, 2009 7:13 am    Post subject: Reply with quote
Arrived yesterday, just before the post strike kicks in.
Gona be working on my Vespa this week end but will crack on with getting this together on Monday
2 bar MAP sensor
Rich H
PostPosted: Fri Oct 23, 2009 9:17 am    Post subject: Reply with quote
Still waiting for my bl**dy gauge!
PostPosted: Fri Oct 23, 2009 10:35 am    Post subject: Reply with quote
Good to see you got a connector with it. These unique/ specialised plugs often end up costing more than the unit they fit.
9XX Girl!
PostPosted: Fri Oct 23, 2009 10:45 am    Post subject: Reply with quote
Yep, it was an eBay purchase (6 inc postage). I messaged the seller asking them to include a bit off the harness too. The seller did so at no extra cost. Gonna solder longer tails on, shrink sleeve each joint and then black heat shrink over the whole lot. Will stager my joints too in order to reduce a bulky bit in the harness.
Page 6 of 8
