turbozetec
Joined: 06 Mar 2009 Posts: 10 Location: woodstock, va
Posted: Fri Sep 04, 2009 1:50 pm Post subject: 79 924 to 87 924s |
| I know this probally has been posted before I tryed to search for it but could find what im looking for. I have a 79 924 and Im buying a recked 87 924s how hard will it be to switch out everything into my 79. Im wanting to change the suspension to the 5 lug and swap motors and transaxels. Will the 87 924s engine bolt right in or with little modifications. Has anybody done this before? |
Posted: Fri Sep 04, 2009 2:03 pm Post subject: |
Dude, look one post below yours. It was the top post in this forum before you posted yours:
http://www.924board.org/viewtopic.php?t=30191 _________________ erstwhile owner of just about every 924 variant ever made |
Khal
Posted: Thu Sep 10, 2009 5:16 am Post subject: |
Or you could always send the tired 924S motor to Broadfoot Racing and have them do this...
104mm Darton Steel Sleeved Block with O-ring grooves (Autosport design)
104mm JE Racing Pistons (Autosport design)
Pauter Racing Rods
88 mm Knife-edged, cross-drilled, balanced 968 Crank
Ported Head
Race Cam
Titanium Valve Retainers
Race Springs
1-7/8" 321 Stainless Racing Headers (Autosport)
2.5" 321 Stainless Cross-over Pipe with V-band clamps (Autosport)
Garret T04E 60 Trim / K26 #10 turbine housing with Stage V wheel - Hybrid Turbocharger
Massive Custom Level Two Intercooler (Autosport)
MAF with ProM controller (Lindsey Racing)
Polished Aluminum Boost Tubes (Autosport)
72# RC Racing blueprinted Injectors
Ceramic coated Intake Manifold, Cam Housing, and Oil Pan
3" 304 Stainless Cat Bypass Pipe
3.5" Cat-back Race Exhaust with twin 3" outlet tips (Autosport)
KEP Pressure Plate with CUP disc
TiAL 46mm Wastegate
TiAL Blowoff valve...
 _________________ '80 924 Turbo |
