CBass
Posted: Sun Sep 06, 2009 9:12 am Post subject: 5 bolt question |
IIRC the stub axles and wheel bearings are the same between 4 bolt and 5 bolt setups on the rear, can anyone confirm or deny this? I see the wheel bearings listed on pelican parts as teh same rear bearings of the 924 and the early 944 making no mention of 4/5 bolt anything. _________________ '81 931 in various states of assembly |
Posted: Sun Sep 06, 2009 3:56 pm Post subject: |
The stub axles depend if your donor is early or late offset. If they are the late offset Alu trailing arms then you need the stub axles to match as they are wider.
Here and here talk about it all in great detail.
69 911 |
924guy
Posted: Mon Sep 07, 2009 10:51 am Post subject: |
i was able to bolt the stub axles right on to the early 944 hubs, no issues there at all. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Mon Sep 07, 2009 12:39 pm Post subject: |
im with 924guy early 944 stuff is a direct bolt on like pocket science pointed out. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
