16V head Q
Goto page Previous  1, 2, 3, 4
Khal
PostPosted: Sat Feb 20, 2010 6:14 am    Post subject: Reply with quote
Martijnus wrote:
The 924 engine doesn't really have special powers that any other engine doesn't...
morghen, if you promise to chant the above mantra daily, then I promise I will chant the following;
Martijnus wrote:
...it's fun to modify that base to the max
'80 924 Turbo
924OZY
PostPosted: Sat Feb 27, 2010 3:34 am    Post subject: Reply with quote
It was used at Le-Mans.
Thats a special power
924 N/A snailshell, superpro linkage bushes, 2.5"exhaust
4.0L ef Fairmont, 3000rpm stall, shift-kit, J3 chip, 3" exhaust, self tuned using tunerpro, soon to be boosted,
expecting 350Kw at wheels at 10psi.
Khal
PostPosted: Sat Feb 27, 2010 4:56 am    Post subject: Reply with quote
It lost.
'80 924 Turbo
PostPosted: Sat Feb 27, 2010 5:40 am    Post subject: Reply with quote
surviving means wining at lemans...the 924 has the special power of being very robust and forgiving...its a tank
red 924 and not red 924
Paulyy
PostPosted: Sun Oct 02, 2016 5:05 pm    Post subject: Reply with quote
So no one found anything close enough even if it required modification to adapt a 16v engine on the 924 block?
924 - Race car project in the works.
951 - 400whp.
gegge
PostPosted: Tue Nov 01, 2016 12:12 am    Post subject: Reply with quote
I am into VW engines mated to the 924 bellhousing.
So far we know that the Audi I5 fairly match and the VW LT 2.4 I6 does as well. These are more or less gasburners based on dieselblocks, similar to our 924 engine. The smallest member in the EA827 family should be the old VW 1.6D, code prefix 068:
https://en.wikipedia.org/wiki/List_of_discontinued_Volkswagen_Group_diesel_engines#Four-cylinder_EA827_diesels
The second gen Audi 100 had the small 1.6 fourpot as a cheaper alternative to the 924 2.0 or even larger I5.
The VW type2 (T3) had different engineoptions: the na I5 (South Africa), 1.6D and can be retrofitted with a 1.9TD (AAZ).
This part is especially interesting:
The 16V KR head does fit the AAZ block
http://vwdiesel.net/forum/index.php/topic,19661.0.html
The AAZ and 1Z share the same block casting and you can safely take a 1.9 TDI motor with 79.5mm bore all the way to 82mm with no issues(been done before). The old 1.6 H-block can be bored to 83mm.
A 1013hp 16V KR head on a 1Z block:
http://forums.fourtitude.com/showthread.php?5761598-7-800-HP-16v-for-drag-project-discussion
A KR/1Z combo with 814 hp:
http://www.boba-motoring.de/?knopf=2011datenblatt#schliessen
Maybe more engine transplant than 16V bolt-on...
Carl Fredrik Torkildsen
Page 4 of 4
