recharging your Air Conditioning
Post new topic   Reply to topic    924Board.org Forum Index -> Links
wdb
PostPosted: Tue May 28, 2002 9:43 pm    Post subject: Reply with quote
To convert a properly functioning automotive R-12 system to FRIGC (FR-12), an installer must:
Recover and recycle the R12;
Evacuate the system ( for approximately 30-45 minutes); using a vacuum pump
Add approx. 2 oz. of Ester (POE) oil
Charge the system to approximately 80 to 90% of the R12 capacity and install the under-hood "system identification retrofit label".
Install retrofit fittings on the high and low side service ports;
It's that simple! In some cases, it may be necessary to adjust the cycling pressure switch on CCOT systems for optimum performance
http://www.refimax.com/products/fr12.htm
http://pacific.bizjournals.com/pacific/stories/1996/07/15/story6.html
dont forget to replace O-rings first
detailed instructions
http://www.refimax.com/products/fr12_instructions.htm#charging
79 924 n/a
"What one man can do, another can do."
Anthony Hopkins, The Edge
[ This Message was edited by: wdb on 2002-05-28 22:30 ]
Post new topic   Reply to topic    924Board.org Forum Index -> Links All times are GMT + 10 Hours
