beario
Joined: 03 Nov 2002 Posts: 139 Location: st albans/cornwall
Posted: Mon Aug 17, 2009 6:59 am Post subject: 034 motorsports vr6 adapter... |
so everyone tsaliking about the 034 adapter plate for the vr6 to o16 audi bellhousing...has any one actually used this and is the porsche 016 b/housing the same as the audi 016...because its an expensive excersize if they are not the same... _________________ theres no replacment for displacement....V8 |
Posted: Wed Aug 19, 2009 12:58 pm Post subject: |
Yes, they are the same.
You'll need to use a 924 N/A or 924 Turbo bellhousing as the 944 uses a different bellhousing on the engine side (the other end of the torque tube is a reversed Audi bellhousing)
Keep in mind that the reason that many don't run other Audi-style engines in these cars is due to a lack of space around the strut towers caused by the angle of the engine. So the cross flow headed engines tend to work better.
A VR6 is wider I believe, so you may have to watch that as you move forward on this.
Good luck _________________ Stefan
