Shurick's 931 build
Goto page Previous  1, 2, 3, 4, 5, 6
PostPosted: Tue Feb 21, 2017 12:47 am    Post subject: Reply with quote
Thanks Shrick. That Delica thingy not sold here either, but other Mitsubishi must run similar clutch, I suspect.
Specs of the clutch plate would be handy, and then I would take you up on the offer of the spacer arrangement.
Shurick
PostPosted: Wed Feb 22, 2017 9:24 pm    Post subject: Reply with quote
Sorry for a delay. The clutch plate I used is Valeo PHC MB-21
Outer diameter 225 mm
Inner - 150 mm
Splines: 23, spline diameter 26.1 mm
It was used on Mitsubishi:
Galant IV (A16_) 2.3 Turbo-D [4D55T] 84 h.p. 1980 - 1984
Galant IV (A16_) 2.0 Turbo ECi [4 G 63 T (ECI)] 170 h.p. 1982 - 1984
L 200 (K6_T) 2.4 i [4G64 (SOHC 16V)] 132h.p. 1996 - 2006 -200303
L 200 II (K__T) 2.0 [4G63] 102h.p. 1986 - 1996
L 200 II (K__T) 2.0 4WD [4G63] 102 h.p. 1986 - 1996
L 200 II (K__T) 2.0 [4G63] 94 h.p. 1987 - 1990
L 200 II (K__T) 2.0 4WD [4G63] 86 h.p. 1987 - 1994
L 200 II (K__T) 2.6 4WD [G54B] 103 h.p. 1989 - 1995
L 200 III (K7_T,K6_T) 2.0 [4G63; 4G63 (SOHC 16V)] 122 h.p. 1996 - 2007
L 200 III (K7_T,K6_T) 2.4 4WD [4G64; 4G64 (SOHC 16V)] 132 h.p. 1996 - 2007
L 300 (L03_P) 69 h.p. 1986 - 1994
L 300 (LO3_P/G, L0_2P) 68 h.p. 1983 - 1986
L 300 II (P0_W, P1_W, P2_W) 90 h.p. 1986 - 2000 -199707
L 300 II (P0_W, P1_W, P2_W) 109 h.p. 1986 - 1990
L 300 II (P0_W, P1_W, P2_W) 112 h.p.1986 - 1997
L 300 II (P0_W, P1_W, P2_W) 88 h.p. 1986 - 2000 -199707
L 300 II (P0_W, P1_W, P2_W) 112 h.p. 1988 - 2000
L 300 (L03_P) 68 h.p. 1983 - 1986
L 300 II (P0_W, P1_W) 112 h.p.1986 - 1997
L 300 II (P0_W, P1_W) 86 h.p.1988 - 1994
L 300 II (P0_W, P1_W) 111 h.p.1994 - 2002
L 300 II (P0_W, P1_W) 106 h.p.1994 - 1995
L 400 (PAOV) 132 h.p.1995 - 2002
L 400 (PAOV) 132 h.p.1995 - 2000
L 400 (PAOV) 128 h.p.1996 - 2005
L 400 (PAOV) 132 h.p.1996 - 2002
Lancer II (A17_) 2.0 Turbo ECi [4G63 T; 4 G 32 T (ECI)] 170 h.p.1981 - 1983
Pajero (L04_G, L14_G) 2.6 4WD [4G54] 103 h.p.1983 - 1987
Pajero (L04_G, L14_G) 2.6 4WD [4G54] 107 h.p.1986 - 1991 -199102
Pajero (L04_G, L14_G) 3.0 V6 [6G72] 141 h.p.1988 - 1990
Pajero II (V2_W, V4_W) 2.6 4WD [4G54] 103 h.p.1991 - 1997
Pajero II (V2_W, V4_W) 2.4 [4G64] 112 h.p.1991 - 1999
Pajero (L04_G) 2.3 TD [4D55T] 84 h.p.1982 - 1986
Pajero (L04_G) 2.6 [4G54] 103 h.p.1983 - 1990
Pajero II (V2_W, V4_W) 2.4 [4G64] 112 h.p.1991 - 2000
Sapporo II (A16_A) 2.0 Turbo ECi [4 G 63 T (ECI)] 170 h.p.1982 - 1983
Starion (A18_A) 2.0 Turbo ECi [4 G 63 T (ECI)] 170 h.p.1982 - 1985
Starion (A18_A) 2.0 Turbo ECi [4 G 63 T/C] 180 h.p.1985 - 1987
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Wed Feb 22, 2017 10:45 pm    Post subject: Reply with quote
Thank you so much.......I'll now source a clutch and then I'll get back to you.
Page 6 of 6
