Shurick's 931 build
Shurick
PostPosted: Sun Aug 09, 2015 6:33 am    Post subject: Reply with quote
Fasteddie313 wrote:
That is sick!! great work
At 1.4 Bar/20psi you have to be getting around 300 crank hp you think? Maybe a bit more?
According to fuel/air consumption from EFI datalog it must be 320-330 hp. Don't sure it's safe to run so much boost on a nearly stock engine. Also don't know how it will withstand longer drives. It may (and sure it will) demand higher capacity radiator for longer punishment than a one burst with wrong boost controller settings.
P.S. It's time to update my signature.=)
WBR, Shurick
'86 924S -- R.I.P.
Shurick
PostPosted: Mon Aug 10, 2015 9:00 pm    Post subject: Reply with quote
Sunday drive @1.2 bar =)
https://youtu.be/v_COurZdFlU
WBR, Shurick
'86 924S -- R.I.P.
Shurick
PostPosted: Wed Aug 26, 2015 8:41 am    Post subject: Reply with quote
Express G31 overhaul: http://www.youtube.com/watch?v=h5ihSjZad8U
Unfortunately, space on SD card ended up during gearbox disassembling. So it's not covered completely.
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Wed Aug 26, 2015 10:43 am    Post subject: Reply with quote
Truly awesome..
PostPosted: Wed Aug 26, 2015 5:30 pm    Post subject: Reply with quote
nice, what did you replace?
red 924 and not red 924
Shurick
PostPosted: Thu Aug 27, 2015 8:28 am    Post subject: Reply with quote
Retaining pins on the 2-3 gear fork jammed and fell off so I couldn't engage gears.
WBR, Shurick
'86 924S -- R.I.P.
kcoyle
PostPosted: Thu Aug 27, 2015 9:15 am    Post subject: Reply with quote
Loved it!
Shurick
PostPosted: Wed Feb 15, 2017 11:45 pm    Post subject: Reply with quote
Almost forgot to tell a story about my new clutch disk.
Spec stage II disc died very fast for some unknown reasons. So I was looking for some alternative and found it for cheap.
Since I use M31/03 flywheel which shares clutch with 944, I can't use direct replacement like Mitsubishi Delica disc, but I manufactured a kit modify it:
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Thu Feb 16, 2017 4:35 am    Post subject: Reply with quote
Holding up well? Other than the clutch..
PostPosted: Thu Feb 16, 2017 9:27 pm    Post subject: Reply with quote
Shurick.....so what exactly have you done with the clutch plate?
PostPosted: Thu Feb 16, 2017 10:45 pm    Post subject: Reply with quote
Right, share with us the materials used to make yourself a cheap clutch please.
Shurick
PostPosted: Fri Feb 17, 2017 10:26 pm    Post subject: Reply with quote
It runs well on 1.1 bar of boost with no issues at all, but I feel it needs larger radiator. Will try to install two-pass aluminium radiator, bigger injectors and bigger oil cooler. And crank up boost to 1.3-1.4 bar.
WBR, Shurick
'86 924S -- R.I.P.
Shurick
PostPosted: Fri Feb 17, 2017 10:29 pm    Post subject: Reply with quote
I made a spacer and heat-treated bolts, drilled out the rivets in clutch and installed spacer.
Much like in this thread, but my spacer is reusable and more solid to accept higher torque.
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Fri Feb 17, 2017 11:37 pm    Post subject: Reply with quote
Yes, I see that...and a very nice job too.
What was the clutch plate from, that you modified? There are no Bronco 11s in Australia, so I'm wondering whether it was a common Euro car.
Shurick
PostPosted: Sun Feb 19, 2017 1:30 pm    Post subject: Reply with quote
It was Mitsubishi Delica diesel clutch plate. I'll post a p/n tomorrow, I need to get back to my home pc to find it. By the way, I can supply the pacer and bolts if you need.
WBR, Shurick
'86 924S -- R.I.P.
Page 5 of 6
