Shurick's 931 build
9xx
PostPosted: Sat Mar 07, 2015 6:35 am    Post subject: Reply with quote
...and speed climbs uncomfortably.
Come on, we all know how slow 924s are. You're propably just having the toofah hallucination
Mikko
All gone: 931 '82 Alpine White, original option "220" G31 with LSD + 3 x 944
Shurick
PostPosted: Sat Mar 07, 2015 6:57 am    Post subject: Reply with quote
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Sat Mar 07, 2015 7:23 am    Post subject: Reply with quote
Only the Americans know
Good luck with that turbo, post some videos when it's running on the car.
red 924 and not red 924
Shurick
PostPosted: Sat Mar 07, 2015 8:08 am    Post subject: Reply with quote
I hope I'll start my season in april, it depends on weather.
WBR, Shurick
'86 924S -- R.I.P.
Shurick
PostPosted: Tue Mar 10, 2015 5:42 am    Post subject: Reply with quote
Not shure it is a performance upgrade, but it's definitely a part of my Frankenporsche.
Created a door card from two pieces of crap:
WBR, Shurick
'86 924S -- R.I.P.
Shurick
PostPosted: Thu Jun 25, 2015 8:14 am    Post subject: Reply with quote
K26-6030-6.10 hybrid built:
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Thu Jun 25, 2015 7:06 pm    Post subject: Reply with quote
that looks right
PostPosted: Fri Jun 26, 2015 12:27 am    Post subject: Reply with quote
Nice...
1980 931S - LSD - FMIC - GTS fuel - hobby
95 M3 manual coupe - summer DD
06 X5 3.0 auto - winter DD
01 RS25 coupe - 90% Retired
06 MDX - bought for mom to DD
81 Rambler BBC 454
97 Tercel long retired/sitting
77 gs750 - 95 300ex - 89 blaster
Shurick
PostPosted: Fri Jun 26, 2015 4:20 am    Post subject: Reply with quote
It looks to me that compressor housing sits too close to the body. Or the engine mount is shot.
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Fri Jun 26, 2015 5:42 am    Post subject: Reply with quote
Engine mount is surely shot.
Mine has much more space...and i guess its exactly the same size.
Shurick
PostPosted: Fri Jun 26, 2015 6:03 am    Post subject: Reply with quote
Ok, looks like it's time for engine mount spring winding.=)
WBR, Shurick
'86 924S -- R.I.P.
Shurick
PostPosted: Sat Aug 08, 2015 9:51 am    Post subject: Reply with quote
Occasionally tested 1.4 bar of boost on a new turbo. It's so scaring fast that you don't have time to analyse your feelings. Going in third, step on throttle, 50-150 sprint and than rev limit comes - just it. You even don't have time to feel any fear. That fast.
Unfortunately (or fortunately?) 48 lb injectors are too small to feed the engine at that kind of boost levels: it learns up to 0.84 lambda @ ~95% duty cycle (while no pinging), so gone back to 1.2 bar boost .
Sadly I hadn't a camera in the car. 1.2 is also impressive and very fast but nothing special. ((((
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Sun Aug 09, 2015 2:21 am    Post subject: Reply with quote
cool, get bigger injectors !
PostPosted: Sun Aug 09, 2015 2:34 am    Post subject: Reply with quote
That is sick!! great work
At 1.4 Bar/20psi you have to be getting around 300 crank hp you think? Maybe a bit more?
81 Rambler BBC 454
PostPosted: Sun Aug 09, 2015 6:19 am    Post subject: Reply with quote
I would guess more
Page 4 of 6
