Stock Alarm
isuras2
PostPosted: Sat May 23, 2009 11:46 pm    Post subject: Stock Alarm Reply with quote
Does anyone have and use the stock car alarm?
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
924guy
PostPosted: Sun May 24, 2009 12:27 am    Post subject: Reply with quote
did before I pulled my 931 apart, and will againwhen i put it back together, though i will probably elliminate the key switch and replace it with a remote fob and simple control board, or a key pad... its a very basic set up, but works just fine...
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
9xx
PostPosted: Sun May 24, 2009 2:37 am    Post subject: Reply with quote
I've got it and I use it, well sometimes. If you open up the doors it'll activate the horn. It sounds a bit of antique and funny but I guess it is better than nothing.
You can see the alarm key hole (black dot) on the side panel next to a door. http://usera.imagecave.com/9xx/4.jpg
Mikko
All gone: 931 '82 Alpine White, original option "220" G31 with LSD + 3 x 944
968rz
PostPosted: Sun May 24, 2009 4:18 am    Post subject: Reply with quote
At least they put the key were they did and not right in the middle of the fender like others.
(Insert puke face here)
Rick
79 924 coupe Petrol Blue 3spd auto (wife's DD)
93 968 coupe Amazon Green 4spd Tip (my DD)
