the webber install removal of the no good stuff
PostPosted: Fri Jan 29, 2010 9:54 am    Post subject: Reply with quote
drool a lil hmmm Stephen has a nice set-up too.
DOCO
PostPosted: Fri Jan 29, 2010 11:07 pm    Post subject: Reply with quote
thanks brad.havent got there yet.and right now its a tad cold out side for working.springs comin and work will again resume.i have a lad whos gonna send me some of his pics.ill keep you posted on this.dave
Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR"
brupska
PostPosted: Fri Jan 29, 2010 11:20 pm    Post subject: Reply with quote
Thanks Doco. I will take some pics of mine when I get there. I have the manifold on now. I have the throttle cable with a hook on the end. It looks like I will have to set up some kind of bracket other then the one supplied. The travel seems too long. After I get the carbs installed. I will know more. It seems the carbs butterflies need to be pulled almost straight down to function. Thanks Brad
DOCO
PostPosted: Fri Jan 29, 2010 11:41 pm    Post subject: Reply with quote
yes thats the same issue im plaged with they want to be pulled straight down.now i know the the linkage on the carbs can be removed and put in anouther position.maybe change the geometry?now mine being left hand drive,i have found that the cable housing is to short to allow the carbs to be pulled straight down.so im thinking on a longer cable,so it can mount under the carbs,and then pull straight down or im gonna see if i can acully change the postion of the carb linkage.but when it warms up a bit.right now its 20 c below and thats not including windchill,and ive no heat in my small garage.winter gotta love it!!!!
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR"
brupska
PostPosted: Sat Jan 30, 2010 12:46 am    Post subject: Reply with quote
Mine is left hand drive and my cable is really short also. Before I started working on this project I assumed the cable pull would be horizontal and not down. If I am correct the pull may only be up or down because of the notch in the throttle shaft on the carbs. If that so then I will have to see!!! I will keep you informed. Thanks Brad
DOCO
PostPosted: Sat Jan 30, 2010 2:11 am    Post subject: Reply with quote
im looking for a cable from a right hand car just a good used on or new if i have to.there outer cable is about 1 fft longer that ours and then you can posistion the cable under the carbs and straight pull
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR"
PostPosted: Sat Jan 30, 2010 2:39 am    Post subject: Reply with quote
fiat22turbo I pmed ya, man.
brupska
PostPosted: Sat Jan 30, 2010 3:25 am    Post subject: Reply with quote
Here is how far I am.
http://carphotos.cardomain.com/ride_images/4/317/3961/38291980004_large.jpg
http://carphotos.cardomain.com/ride_images/4/317/3961/38291980003_large.jpg
PostPosted: Sat Jan 30, 2010 4:14 am    Post subject: Reply with quote
Dang they look brand new.
DOCO
PostPosted: Sat Jan 30, 2010 4:55 am    Post subject: Reply with quote
looks real good!!!cant wait till these puppys stroke up!!!!gas milage....WHO CARES!!!
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR"
brupska
PostPosted: Sat Jan 30, 2010 5:26 am    Post subject: Reply with quote
Yes they are brand new. I bought the Redline kit off of ebay a few month ago. Everything was still in sealed bags.
brupska
PostPosted: Sat Jan 30, 2010 2:31 pm    Post subject: Reply with quote
Well I got the back carb on almost all the way except for the bottom back bolt!!!!! I had to use a rubber mallet to bend the coolant transfer pipe down a little to get the carb on. The AC line into the firewall was a tight fit. I don't know if I can get a aircleaner on it or not. I gave up after dropping the bottom nut about 4 times. You really have to hold your tongue right to get that one on. Brad
http://carphotos.cardomain.com/ride_images/4/317/3961/38291980005_large.jpg
brupska
PostPosted: Sun Jan 31, 2010 1:25 am    Post subject: Reply with quote
I guess I am gonna try a pc. of hose acting like a flexable nut driver for the back bottom nut on the back weber. I fought it all night until about 2am. No luck yet!!!!
brupska
PostPosted: Tue Feb 02, 2010 10:21 am    Post subject: Reply with quote
Hey Doco. The stock left hand drive cable is also to short. You might have to order a longer cable from Lokar or CSR performance
DOCO
PostPosted: Tue Mar 30, 2010 5:41 am    Post subject: Reply with quote
hi all these are not mine.they are curtousy of vince.
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR"
Page 4 of 5
