Trgrenier
Posted: Wed Feb 06, 2013 6:47 am Post subject: 1JZ-GTE? Lets give it a go! |
So after searching around, and seeing that people have got the 1J into a 944, I have decided to take up the task
Car-77 924
Engine 1JZ (2.5l inline 6 twin turbo)
Transmission 951 turbo
The work is going to be done by a fabricator friend of mine who is familiar with the transaxles are cars use as he spent 10 years building dune buggies before he settled down and started his shop.
I have ordered the engine it lands on the 10th, I am just sourcing the tranny and 944 torque tube (which will have to be cut and balanced). When I get the project started ill make sure to post pictures and a detailed write up so we have a choice other then the v8 swap.
Anyone know what I can do with the suspension!? _________________ 1976 924 project. 2004.5 bmw 330xi m package for winter. |
Posted: Wed Feb 06, 2013 2:22 pm Post subject: |
Subscribed. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Feb 06, 2013 4:10 pm Post subject: |
Horrified.
Trgrenier
Posted: Thu Feb 07, 2013 3:46 am Post subject: |
Curiosity, so I've put a couple hours in today-few more to come with a couple pictures. However anyone know of any tricks on removing the brake booster? Another question, is anyone looking for any parts for the 2.0 slow? or CIS system? as both as in good working order. _________________ 1976 924 project. 2004.5 bmw 330xi m package for winter. |
jim kleyh
Joined: 24 Apr 2012 Posts: 55 Location: pine falls, manitoba, canada
Posted: Thu Feb 07, 2013 4:14 am Post subject: re parts |
Hi, I will likely be looking for parts this spring if they are still available. I did get my car to run this past fall but likely need to go throuugh everything from A-Z as soon as the weather warms and the snow's gone from the car's roof. Keep us posted. _________________ oldcarman-77 porsche 924 and one of the ugliest motorhomes on earth. |
Trgrenier
Posted: Thu Feb 07, 2013 5:51 am Post subject: Re: re parts |
jim kleyh wrote: | Hi, I will likely be looking for parts this spring if they are still available. I did get my car to run this past fall but likely need to go throuugh everything from A-Z as soon as the weather warms and the snow's gone from the car's roof. Keep us posted. |
I was quite lucky that our snow started to melt which is why I have started already (live in Calgary Alberta). Let me know and give me a PM when you know what you want as far as interior goes you don't want anything I've got. Engine was this car actually ran perfectly. I just got bored of the amount of "pull" it has from factory _________________ 1976 924 project. 2004.5 bmw 330xi m package for winter. |
Posted: Thu Feb 07, 2013 6:40 am Post subject: |
The booster is a piece of cake to remove, three bolts under the dash, disconnect the push rod to the master cylinder, and out she comes (well, of course, you also have to disconnect the lines to the master cylinder!).
Kokeln used to make a dual master boosterless setup for the 944 that should be essentially bolt-in for the 924, but I'm not sure if they still make them. If you can find one of those, that would be the easiest way to deal with it, although the brake feel will obviously be quite a bit different.
If you can't find the Kokeln setup, then the next best thing would be to go with a Tilton dual cylinder boosterless setup. They are not cheap, and they are not model-specific, so it will require some fabrication to mount, but nothing like what's ahead of you for doing the engine swap
FWIW, I am a Tilton reseller, so let me know if I can assist you with any further information on the Tilton stuff. _________________ erstwhile owner of just about every 924 variant ever made |
