Lightning22
Posted: Sat Nov 22, 2008 8:20 am Post subject: Mega Jolt on a 924? |
Has anyone fitted one of these systems to their 2.0 924? I'm in the process of fitting one to a Midas Gold and would be interested to hear if anyone has done the 924 with one.
Is the stock system so bad? 25mpg from a fuel injected, streamlined car that in all honesty ain't that quick seems pretty poor to me. I had a 2.0 Alfa 75 that ran at 150bhp and delivered around 40mpg in a car that was nearly as aerodynamic as a brick, all that on essentially the same fuel injection system..
Rich
endwrench
Posted: Sat Nov 22, 2008 3:29 pm Post subject: |
Ya, I have one on mine. It was one of the first "mods" I did to it after getting it up and running. I think the OE ignition curve is heavily orientated towards emmisions namely NOX. These motors can handle a far faster more aggressive ignition curve. I think this is the biggest advantage of going MJLJ.
Lightning22
Posted: Wed Nov 26, 2008 7:28 pm Post subject: |
Hi Todd,
Thanks for the reply, did you find an improvement in fuel economy?
Rich |
endwrench
Posted: Tue Dec 02, 2008 3:13 am Post subject: |
Didn't really drive it long enough before moving on to EFI and a blower.
macBdog
Joined: 16 Aug 2004 Posts: 1111 Location: Brisbane, Australia
Posted: Tue Dec 02, 2008 8:54 am Post subject: |
I had a mega jolt too, nice bit of kit. Worked fine, was able to dynamically dial in advance no probs. _________________ 1979 931 with a 350 chev
1973 911E with EFI
| p-talk wrote: | I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways  |
flyguy
Joined: 31 Oct 2008 Posts: 75 Location: Hamilton, Ont
Posted: Thu Dec 04, 2008 4:25 am Post subject: |
| Hey guys. I got a 77' 924. What is this Mega Jolt thing? What does it do? To me it sounds like it improves gas milage? |
Lightning22
Fast924S
Joined: 18 Feb 2005 Posts: 39 Location: New Haven, CT
Pieter
Posted: Fri Jan 02, 2009 8:24 pm Post subject: |
Has anyone done this type of conversion on a US spec 924 (either with EFI or CIS)? Was there any big difference in performance? from the Hayens manual it seems that there is a more than 5 degree difference between the US and Euro spec vacuum advance curves. Also, a 1 point in CR difference should translate to around 3% difference in peak BHP, so the differences between Euro and US should be less than this, if everything else is the same.
It seems to me that my vacuum advance is not operational at all, so I will be adding on ignition to my VEMS EFI, just need to source the parts for this(coil pack, trigger wheel and pickup). But it would be great to hear from other peoples experiences on EFI and ignition on the US spec motor. |
