Ideal A/F ratio?
PostPosted: Fri Nov 28, 2008 5:52 pm    Post subject: Ideal A/F ratio? Reply with quote
been reading up on tuning and it seems there isnt a definitive answer for the ideal A/F for my soon to be boosted NA
I know the stoichiometric A/F is 14.7 but whats a good A/F taking everything else such as power..efficiency..detonation etc into account? some say 12.7-1 some say 13.1-1
Educate me wise dudes!
1979 NA
my Porsches Arse!!!
PostPosted: Fri Nov 28, 2008 7:47 pm    Post subject: Reply with quote
At WOT, when the boost kicks in...3000-3500 or whatever rev it comes in...i would even use 11.5-1..then you can lean it out a bit as it climbs up the revs.
CBass
PostPosted: Sat Nov 29, 2008 6:38 am    Post subject: Reply with quote
There is no ideal AFR per se. For a turbo engine you'd want it a little richer than a NA application to keep down combustion temps. Go richer than you think you need to, start at 10.5/11:1 and conservative timing and start tuning from there.
What kind of boost levels are you expecting to see and what kind of internal build?
Access to a dyno? EGT probe?
Raceboy
PostPosted: Sat Nov 29, 2008 6:53 am    Post subject: Reply with quote
For NA you shouldn't go richer than 13:1 at WOT, for turbocharged car, 12-12.5 is the good point.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
CBass
PostPosted: Sat Nov 29, 2008 9:21 am    Post subject: Reply with quote
That's highly dependent on the engine. Often you'll find the AFR dipping up and down on a properly dyno tuned engine. EGTs are also a huge consideration, especially if using stock pistons with narrow ring lands and a thin crown.
It's much better to start too rich and then lean out until it stops making more power while keeping an eye on your exhaust temperatures. A dyno and an EGT probe are the best way to do this. If you don't know what your EGTs are it's better to err on the side of caution and run a little rich with a little less timing.
PostPosted: Sat Nov 29, 2008 10:35 am    Post subject: Reply with quote
I want close to Raceboys level of performance (minus of course all the weight loss)..I wantthe max HP the drivetrain can happily handle
whats that ..mm 200hp at the engine?
so boost somewhere around 10 maybe maybe maybe 11 or 12 on stock compression 9:3-1
Mods are basically
1) Headstuds instead of bolts
2) newly rebuilt engine with 3 angle valve job, new rings, seals etc etc etc
2)BAE manifold
3)Garrett T25 turbocharger
4) EFI with O2 sensor...Edis4 with crank triggerwheel
5)951 intercooler
6)possible water/methanol injection
7)Thicker core aftermarket radiator, twin thermo fans
8)And a partridge in a pear tree
When its all done ill get it dyno tuned...although the people ive asked dont tend to understand or wanna touch megasquirt ...might ask leadfoot and macbdog to help out
So basically start rich then move up 11.1 ---13.1
1979 NA
my Porsches Arse!!!
huckster
PostPosted: Sat Nov 29, 2008 2:52 pm    Post subject: Reply with quote
So you went with megasquirt and a t25 I am doing the same! Wonder who will finish first?
77.5 project car have never driven. burgundy
79 parts car sea foam. blue new clutch and shifter bushings
79 driver yellow new shocks water pump shifter bushings
96 ford escort sw
PostPosted: Sat Nov 29, 2008 2:57 pm    Post subject: Reply with quote
Well if you come out here as we discussed you could have it up and done right quick!
3 928s,
PostPosted: Sat Nov 29, 2008 4:27 pm    Post subject: Reply with quote
Cool wheels, Huck. Did you add them to Rasta's Pseudo-Official and Marginally Comprehensive Wheelio-nanzaŠ thread?
Raceboy
PostPosted: Sat Nov 29, 2008 5:22 pm    Post subject: Reply with quote
It depends more on fuel. If you have good enough fuel (at least 98 RON), you can use AFR what's called "lean best torque" and on gasoline this point is around 13.0. Anything leaner or richer, you won't benefit (or if you will, something else is off).
On turbocharged car, one would want to go to point "rich best torque" and that is around 12.5. But, on boosted car you will be cramped by engine design and on turbocharged 924 I wouldn't go leaner past 12.2.
On properly tuned engine @ WOT, AFR's (at least on my car) are steady. I had no need to richen it up even on max torque area where knock occurs first.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
PostPosted: Sat Nov 29, 2008 6:48 pm    Post subject: Reply with quote
YOU WILL...im slow , its my first major car project , ive stripped everything on this car down to nuts and bolts (minus the gearbox) and im broke
T25 turbo hey? good choice :p
p.s when you finish first i can pick your brain and borrow your megatune tables
Ok thanks raceboy ...i think im getting it
just read the following article which also helped "rich best torque" and "lean best torque". (it doesnt take into account boosted applications or 924 restrictions though.
http://www.max-boost.co.uk/max-boost/internet_articles/Air%20fuel%20metering.htm
So full load at WOT were talking around 12.2
how about idle....cruising etc?
p.s will be running 98 octane
1979 NA
my Porsches Arse!!!
Min
PostPosted: Sun Nov 30, 2008 4:25 am    Post subject: Reply with quote
idle around 13.5, cruise as lean as it'll go without lean surging.
Min
tuurbo
PostPosted: Sun Nov 30, 2008 8:08 am    Post subject: Reply with quote
Are you trying to maximize / optimize HP or reliability or ...is that just the way it's done?
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
PostPosted: Sun Nov 30, 2008 8:28 am    Post subject: Reply with quote
I think off-load leanitude is for fuel efficiency.
Min
PostPosted: Sun Nov 30, 2008 6:26 pm    Post subject: Reply with quote
rasta is correct, you want it as lean as possible while cruising because that way you get the best fuel economy.
Min
