exhaust help
turbellion
PostPosted: Thu Dec 11, 2008 2:14 pm    Post subject: exhaust help Reply with quote
gday just wondering want the ideal exhaust setup for a 1977 NA would be.
i want it to be slightly louder than stock but still relatively quiet.
no cat and a single muffler under the trunk
so what would the ideal tubing size be for my car with basically a straight through muffler. i was thinking 2.5 or would it be 2.25??????? help!!
thanks
PostPosted: Thu Dec 11, 2008 11:08 pm    Post subject: Reply with quote
I'm running 2.5" on the racecar, doesn't suck exactly! Yes, this with a single large oval muffler back under the trunk should sound decent. I have such a muffler, a Thrush brand I think, big and heavy but works well when I need to get the car quiet for DE's (normally, with the full race exhaust, it's too loud to communicate).
The stock exhaust manifold seems to quiet up the car a good bit as well; when we ran a single supertrapp at the end of the pipe with stock exhaust it was still rather quiet. Though note that this was also with like 2" piping IIRC. So if you find that the straight piping and single oval muffler is too quiet, that might be one option to consider for both more noise and performance.
Then again, it's quite a bit of money (about $250 for a new header) and wrenching; if you don't wish to go to that much trouble, you could try a Dynomax race bullet muffler from Racer Parts Wholesale. They're cheap, durable, and loud - I run 2-3 at the same time on my racecar (with 2.5" pipe and MSDS header), and it's VERY loud. One of these behind a stock exh. manifold would probably be plenty of loud for a street car!
