Joined: 01 Oct 2004 Posts: 15510 Location: Woodstock IL
Posted: Thu Sep 25, 2008 11:45 pm Post subject: Couple of questions on format buttons |
When creating a new post, when you roll over the format buttons, it displays some usage information. For example, rolling over the LIST button displays the following:
Code: | Ordered list: [list=]text[/list] (alt+o) |
What is the alt+o for? All of the buttons have the alt+ something, and I'm trying to figure out what that means.
Also, with the LIST feature specifically, I finally figured out that using [*] causes a bullet to appear...but where is this documented? How do you make an "ordered list" with numbers? I've been trying to figure that out for ages...
Are there other "hidden" or undocumented features for any of the other tags? Like, for example, with the IMG tag, can you specify a size for the image so that a huge image can be resized on the fly (kind of like setting image size tags in HTML)? _________________ 75 Fiat X1/9 | 80 US 931 '941' | 78 Poli-Form |
Posted: Fri Sep 26, 2008 2:48 am Post subject: |
phpBB Code Guide
The "alt+o" is a keyboard shortcut for the command. _________________ Toofah King Bad
- WeiBe (1987 924S) - 931 S3
Posted: Fri Sep 26, 2008 3:23 am Post subject: |
OK, just did some checking, the alt+ trick is a stupid MSIE-only feature. I HATE browser-specific extensions. Doesn't work in firefox. No big, at least I know now.
Thanks for the link...I thought I had followed one in the FAQ link above, but it didn't have the same info, so this is what I needed on the LIST feature. _________________ 75 Fiat X1/9 | 80 US 931 '941' | 78 Poli-Form |
