924aussie
Joined: 02 Feb 2006 Posts: 1009 Location: Chinchilla Queensland Australia
Posted: Mon Sep 22, 2008 11:05 pm Post subject: negative post on battery |
No this is not a negative forum post on a battery.
What I would like to know is it good or BAD practice to connect a earth connection from a device direct to the (-) terminal on a battery.
I know some high performance speakers need to be connected direct to the positive terminal but I am wondering about the negative.
alan _________________ green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold |
datatrain
Joined: 15 Sep 2007 Posts: 441 Location: Osoyoos, British Columbia
Posted: Tue Sep 23, 2008 2:32 am Post subject: Negative term |
I think it depends on what your connecting. In order to complete a high current curcuit all parts of the wiring must be capable of carrying the load.
Usually a connection to the chassis is sufficient. However if you splice into a small ground wire, there could be a problem with capacity.
You'll note the battery ground wire to chassis is quite large. So a chassis ground connection will carry any load.
The reason some items want to be connected to the + of the battery is to ensure the wire size is adequate for the device and often it has a separate fuse for protection.. _________________ '78 924 NA with Collector plate
33 year old car, with me for 21 yrs
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR |
wombat
Joined: 07 Jun 2008 Posts: 422 Location: Melbourne, Australia
Posted: Tue Sep 23, 2008 6:44 pm Post subject: |
I dont think that it would matter all that much for most things. The main problem I can see with - straight to the battery is that it may confuse people working on the car later, I usually assume most things running to engine bay to be not earth (ground) and it could be a royal waste of good copper, Man with copper prices the way they are I wouldnt waste it. _________________ 1977 924 2.0 Auto |
