Cheap 944 Engine on eBay
bacook
PostPosted: Fri Aug 31, 2001 9:31 am    Post subject: Reply with quote
For those of you who would consider a 2.5 944 engine in their 924.
http://cgi.ebay.com/ebaymotors/aw-cgi/ebayISAPI.dll?ViewItem&item=594870796&r=0&t=0
Dave
PostPosted: Fri Aug 31, 2001 10:36 am    Post subject: Reply with quote
a 2.5L in a 924 would be a 924S
larso
PostPosted: Fri Aug 31, 2001 11:05 am    Post subject: Reply with quote
why bother, 944s don't have that much more pep, 0-60 in 9 seconds, they are about 5 times more expensive to repair...put a rover in it for christ sake
Dave
PostPosted: Sat Sep 01, 2001 10:32 am    Post subject: Reply with quote
a 944 goes 0-60 in 7.8 seconds not 9
larso
PostPosted: Sat Sep 01, 2001 3:22 pm    Post subject: Reply with quote
yeah, if you over rev it, if it is tuned, if you have a light driver in it, if you forget to shift, if you are highly optomistic and have a biased opinion, if you have a 944 engine in your car and want to protect it.
Most road and track tests claim 9.0.
[ This Message was edited by: larso on 2001-09-01 14:22 ]
AppleBit
PostPosted: Mon Sep 03, 2001 4:50 am    Post subject: Reply with quote
I always read from the original R&T and other magazines it was 8.5...
yeah, I seen some 7.8's as well....
Although the 924 was in range from 9.5 to 11.3 to 60...
And the Geo Metro TT/AWD was 3.4 to 60...
but that model never came out...
damn.
Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine
larso
PostPosted: Mon Sep 03, 2001 6:15 am    Post subject: Reply with quote
it's all about how high u rev it and what type of tires and wheels are on the car.
But if there is a lot of nonsense going around, then it's most likely not a fast 0-60 car...for example, you don't see corvettes getting times of 6-9 seconds, they are always around 6.
Cbass
PostPosted: Sat Mar 02, 2002 2:48 pm    Post subject: Reply with quote
Whats the point in using the stock 944 motor? It wasn't really much better than the 924 engine. It had better tech, but they never put it use. Besides, it's not like the 944 motor has any good power in it.
Get a 944 turbo motor if you're going to swap. There is a ton of power in the turbo.
PostPosted: Sat Apr 20, 2002 12:30 am    Post subject: Reply with quote
I have to agree with cbass go with a turbo mototr and set up a page showing the swap also has anyone ever tried to run a 911 turbo conversion in a 924/944, i think that would be kinda interesting, it puts out 420 bhp plus if they use the new angine it has the vario cam
