jonny924
Posted: Tue Aug 05, 2008 7:03 am Post subject: 1977 924 rough idle/stalls |
Just got this car has been sitting, installed new fuel pump and plugs, cap, rotor, and fresh fuel. Car will start and idle nice for about 3 sec and start to spudder and then dies, will restart and do the same thing. Checked timing and adjusted should be really close but no change..-- Also has no throttle response if you go to give some throttle wants to bog and die out..
Need some help please - thanks to all who do |
Posted: Tue Aug 05, 2008 7:46 am Post subject: |
Agent jonny924, your mission if you choose to accept it, (and you should) is to replace all rubber vacuum lines in the engine compartment. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Tue Aug 05, 2008 9:29 am Post subject: |
It will listen to the Hound of Plaid, or it will suffer. Yesssss. . . _________________ Toofah King Bad
968rz
Joined: 21 Aug 2006 Posts: 537 Location: S. E. Wisconsin
Posted: Tue Aug 05, 2008 11:57 am Post subject: |
Also do a search here for AAV, cold start valve and fuel pressure test. _________________ Rick
79 924 coupe Petrol Blue 3spd auto (wife's DD)
93 968 coupe Amazon Green 4spd Tip (my DD) |
Posted: Tue Aug 05, 2008 9:55 pm Post subject: |
Even before that, I'd pull injectors and make sure they're spraying... I'm betting the fuel distributor may be gunked up... _________________ Vaughan Scott
