engine swap clutch
mcadam1121
PostPosted: Tue May 27, 2008 11:23 am    Post subject: engine swap clutch Reply with quote
im goin to be putting a gm 3800 v6 in my 77 924
im trying to figure out what clutch im goin to have to use
the 3800 came in a camaro with a manual so getting the flywheel and pressure plate wont be a problem
but the clutch disc is goin to be a problem
the 3800 has a 9 5/8 diameter disc and it has a 26 splines
i counted the splines on the porsche clutch and it is 24 splines
i can find a 9 5/8 clutch but the 24 splines is goin to be a problem
i found a clutch from an izuzu pick up that is 9 1/2 and has 24 spline but im not sure how big the diameter of the shaft is on the porsche
any body no what i should look for
The Ginger
77 porsche 924 Martini
PostPosted: Tue May 27, 2008 1:23 pm    Post subject: Reply with quote
You've test fitted your V6 to the 924 with V6 bellhousing attached?
mcadam1121
PostPosted: Tue May 27, 2008 1:26 pm    Post subject: Reply with quote
nope
but im goin to make it work
im goint to make a plate that mounts to the bell housing and then to the torque tube
The Ginger
endwrench
PostPosted: Wed May 28, 2008 8:54 am    Post subject: Reply with quote
The 924 disc is 8 1\2" x 13\16" x 24t
The 931-944 disc is 8 13\16" x 1 1\32" x 23t
The biggest disc I can find to fit your application is the Vanagon and Quantum. They use a 9" x 13\16" x 24t disc.
Todd
v8carreragts
PostPosted: Wed May 28, 2008 10:07 am    Post subject: Reply with quote
If you want something larger, try Kennedy Engineered Products. They may be able to make something up.
mcadam1121
PostPosted: Wed May 28, 2008 10:35 am    Post subject: Reply with quote
yea the 9 inch is all that i could find too ill either go with that or ill have to have one made
The Ginger
