Water pump help???
andytuks
PostPosted: Tue Apr 22, 2008 10:00 pm    Post subject: Water pump help??? Reply with quote
Hey, No water comes thru when i try to clean my windscreen, does this mean that my water pump is broken?, is it a serious problem, easy to fix?
hope you know what i mean.... thanks
PostPosted: Tue Apr 22, 2008 10:12 pm    Post subject: Reply with quote
can you hear it buzz when you pull the lever ?
5150
PostPosted: Tue Apr 22, 2008 10:25 pm    Post subject: Reply with quote
*if* you can hear the pump then chances are the nozzles or the little plastic non-return valve are just blocked, could also check the end of the pipe inside the bottle, it could be clogged there.
Mars Red '78 Euro 924 n/a
http://www.cardomain.com/id/5150_uk
Graphite? Grey Metallic '85 (late model) 944 2.5
There are two kinds of pedestrians: the quick and the dead.
Rich H
PostPosted: Wed Apr 23, 2008 12:54 am    Post subject: Reply with quote
Bypass the non return valves
PostPosted: Wed Apr 23, 2008 5:07 am    Post subject: Reply with quote
I had 2 problems that needed fixing with mine. 1) the elect. connection at the pump needed cleaning and 2) the "non-return" valves were blocking flow in both directions. You can get by without them - just need to wait a little longer for the fluid to come up the line. -But of course that's better than not having to wait so long, and then getting nothing out of the squirters.
Martijnus
PostPosted: Wed Apr 23, 2008 8:14 am    Post subject: Reply with quote
but the pump is working then? mine doesn't do anything... guess it's the wiring but haven't got that high on my prioritylist.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
bcblase
PostPosted: Wed Apr 23, 2008 2:29 pm    Post subject: Reply with quote
Check the hoses for kinks too - they seem to like to kink up where the hose bends when the hood is shut. My pump was buzzing good, but no fluid was coming because of the kink that only blocked the flow when the hood was shut.
I also bought an extra pump just for safe keeping.
BC
1987 Porsche 924S - track toy
1986 Mercedes 190E 2.3-16v - autocross
2007 F-150 5.4L Lariat Supercrew - tow beast
1994 Volvo 850 Race Wagon - 24 Hours of Lemons Car
2001 BMW 325xi - daily driver
