daniel
Joined: 18 Jun 2009 Posts: 670 Location: Sydney, Australia
Posted: Tue Sep 01, 2015 12:40 pm Post subject: |
Regrinding the cam lobe can change all aspects of the cam including lift. If the base of the lobe is ground down then the valve has to travel up further before it meets the lobe, hence creating more lift. Obviously the valve can not move beyond the seat so lash caps are used to make up the difference.
Quote: | Some have postulated that this approach will accelerate lobe and lifter where because the lobes necessarily become more pointed. |
I think if you built a engine with such a radical cam to make noticeably more lifter wear, the last thing you would be worried about is lifter wear! _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Posted: Wed Sep 30, 2015 8:29 am Post subject: |
Or perhaps not. Stand by for pics. _________________ Toofah King Bad
Posted: Mon Oct 12, 2015 6:37 am Post subject: |
Cam Failure. _________________ Toofah King Bad
