motormouth
Posted: Sun Aug 23, 2015 8:45 am Post subject: |
I usually frequent this board just to read your posts Rasta lol. You're way more amusing than the Honda guys. |
friggin
Posted: Sun Aug 23, 2015 3:57 pm Post subject: |
Soooo any help? _________________ 1979 924 stocker soon to be autocross beast |
motormouth
Posted: Mon Aug 24, 2015 11:27 pm Post subject: |
I believe the consensus was that Integral cams were very good, but the company is now defunct. They were cheaper than anyone else's cams and went out of business quite some time ago. Ideola found someone who was doing regrinds of their profiles, though for quite a price. |
Posted: Tue Aug 25, 2015 7:04 am Post subject: |
Yes, we can still get Integral profiles done as a hard-faced cam. Last few I did were in the $650 range, so not cheap. I have two of my own that I'm planning to have reground, so I'll be checking current pricing from the supplier shortly.
As for using a Turbo profile on an NA build, I don't think it would be awful, but I would strongly recommend sticking with a Stage 1 for any car that will spend any amount of time on the street. If you plan to supercharge, I think either NA or Turbo profile will be adequate, but I would lean toward the Turbo profile if it were my project. _________________ erstwhile owner of just about every 924 variant ever made |
daniel
Joined: 18 Jun 2009 Posts: 670 Location: Sydney, Australia
Posted: Tue Aug 25, 2015 3:25 pm Post subject: |
Not dishing Integral cams in anyway, I have never used one. I went down the path of having a cam reground and used spacers on the tips of the valves - saved a LOT of money. I used Paeco, great people, very friendly and easy to deal with.
I used there POR-7200 cam with an 11:1 motor in my race car, stock internals aside from forged custom pistons to give the compression and still using CIS. Although this motor is in a race car it would be fine in a road car.
I got the valve spacers from these guys: http://www.precisionshims.com.au/ _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Posted: Tue Aug 25, 2015 8:24 pm Post subject: |
Thanks for that! Been looking for a source for 9mm lash caps for a while. Do you recall approximate price per piece? _________________ erstwhile owner of just about every 924 variant ever made |
daniel
Posted: Wed Aug 26, 2015 7:10 am Post subject: |
He has prices on his website last I checked? But very cheap _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
Posted: Wed Aug 26, 2015 8:09 am Post subject: |
daniel wrote: | He has prices on his website last I checked? But very cheap |
Nope, you have to submit a request for quote...will do that when I have a chance to spec out what I might want, just wondered if you remembered off hand. One of the other sources I found was for Ferrari, and they were, as expected, carrying Ferrari prices. _________________ erstwhile owner of just about every 924 variant ever made |
daniel
Posted: Wed Aug 26, 2015 12:01 pm Post subject: |
I remember paying something like $30-$40 for everything I needed plus a few extras including shipping. They are very good quality and very reasonably priced. _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
WEASEL149
Joined: 19 Aug 2005 Posts: 595 Location: UK, Sheffield
Posted: Thu Aug 27, 2015 3:16 am Post subject: |
ideola wrote: |
Thanks for that! Been looking for a source for 9mm lash caps for a while. Do you recall approximate price per piece? |
+1! Thankyou!
As Ideola says, some places making shims have extortionate prices. _________________ 1979 UK 932 |
daniel
Posted: Thu Aug 27, 2015 8:46 am Post subject: |
You guys know there in Australia right? _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
WEASEL149
Posted: Thu Aug 27, 2015 8:58 am Post subject: |
daniel wrote: | You guys know there in Australia right? |
Yeah, makes no difference to me and probably means very good quality _________________ 1979 UK 932 |
friggin
Posted: Sun Aug 30, 2015 6:07 am Post subject: |
So you're saying instead of a bigger cam you used spacers? And it works the same?
Why has this not caught on and replaced bigger cams in general? _________________ 1979 924 stocker soon to be autocross beast |
Posted: Sun Aug 30, 2015 6:57 am Post subject: |
For valve lash, spec tolerance gap between the cam with the valve closed/lobe up and lifter.
It has an effect on valve lift if it's out of spec but this is not a way to increase lift, it's to get the tolerances correct.. _________________ 80 Turbo - Slightly Modified |
Posted: Sun Aug 30, 2015 7:21 am Post subject: |
Shims are used in two scenarios:
1. Stock cam that is ground down to a different profile which requires a shim to maintain proper valve clearance.
2. Any cam that uses a solid lifter such as the Sten Parner units we had commissioned a few years back.
The Integral profiles we are currently producing are a "hard-faced cam", which is a weld-and-regrind approach, which maintains proper cam circle and eliminates the need to use shims, unless you're combining it with solid lifters.
The Paeco and WebCam options are simple regrinds on existing stock profiles. Some have postulated that this approach will accelerate lobe and lifter where because the lobes necessarily become more pointed. _________________ erstwhile owner of just about every 924 variant ever made |
