Warped Guest
Posted: Mon Apr 15, 2002 1:19 pm Post subject: |
At first I was thinking that I might not have too much of a rust problem from my water damage, but now, the more I look at it, and think about it...I'm starting to get worried.
I took some pictures to show you, but I haven't got them onto a web page yet...Until I do, what is everyone experience with rust?
What kind of shop can I take a non running, striped interior car too, so that they can weld a new bottom for my car?
I do not have any holes going through the car, but I do have some crackage (in the corners, and the whole driver and passenger side is covered with a greenish yellow.
More importantly, how much does it cost to have a new bottom welded for a 77 924 Porsche?
Thanks |
AznDrgn Guest
Posted: Mon Apr 15, 2002 2:38 pm Post subject: |
I would think that new floor pans would be a lot of money and probably not worth it. The greenish yellow stuff in the corners your seeing sounds more like the glue for the carpets than rust. Post the picts and we'll be able to see it better and help out more. |
Posted: Mon Apr 15, 2002 6:40 pm Post subject: |
you're unlikely to find anyone here with experience with rust in the floorpan because they don't.
The only way you get rust in 924 floors is because of a bad repair job and the repair should be obvious. If it hasn't been damaged I'll bet it's not rust you're looking at. |
Warped Guest
AznDrgn Guest
Posted: Tue Apr 16, 2002 11:33 pm Post subject: |
All of the yellow stuff looks like glue to me. You have a little bit of rust but it doesn't look bad at all. The only two spots I saw were a little ring of it around the circle on the second picture and maybe some in the black spray paint on the first picture. |
Posted: Tue Apr 16, 2002 11:58 pm Post subject: |
Yeah, you got nothing to worry about, it's glue. There is rust around the edges of the circle. Here's why. That's a metal disc that's glued into the floor to fill a hole presumably used in the assembly process. It looks like that disc is rusting around the edges. You could cut it out with a razor knife, clean the rust off and repaint, then glue it back in.
No worries, though - put some carpet on that car! LOL
teo
Joined: 07 Sep 2001 Posts: 637 Location: Hungary, Europe
Posted: Wed Apr 17, 2002 2:22 am Post subject: |
and forget the black carpet set you are looking for, get the one from that other Martini TroyDest have found:
http://www.924board.org/viewtopic.php?topic=2544&forum=3&2
That's what makes it a Martini mostly.
Smoothie Guest
Posted: Wed Apr 17, 2002 2:34 am Post subject: |
When I have a problem with a limited amount of rust, I treat the area first with rust converter. It's a liquid with the consistency of water and includes phosphoric acid as the active ingredient. You're supposed to soak the rusted area for a day, so I spray some on and lay paper towels over it and spray some more on top - press the paper towels into complete contact with the metal so the solution is held there. Spritz the are periodically to keep it wet. Well, that was a pain. You could do all of that or get the stuff that come in an aerosol can and is in solution with clear lacquer. I think the brand name is either RustOleum or Naval Jelly and the stuff was formerly marketed by Duro. Save yourself a lot of trouble - buy this and spray it on where it's needed. Then after whichever rust treatment you use, top it with something like POR-15 ("Paint Over Rust"-15). http://www.POR15.COM |
Smoothie Guest
Posted: Wed Apr 17, 2002 2:37 am Post subject: |
Oh yeh - more important than treating the rust - wear a respirator when using anything with phosphoric acid. The stuff eats lungs. Also keep it off the skin - wear rubber gloves. |
Joes924 Guest
Posted: Wed Apr 17, 2002 2:50 pm Post subject: |
See not a problem, way to go guys.
