Components needed for a euro spec engine mod
GregSC
PostPosted: Sat Jul 19, 2008 12:02 pm    Post subject: Components needed for a euro spec engine mod Reply with quote
I have a 77 N/A that I am in the process of restoring. It is a Martini so I would prefer to keep it as stock as possible (at least to the eye). With that said I would like to get a little more out of the engine than the 95hp that the current XH engine provides. After reading several posts here on this site it seems that a good choice would be to upgrade to the equivalent European engine (XK engine).
If that is a viable option (and I'm open to correction), my questions are what components do I need to complete the transformation? What are the steps necessary, and where is a good place to find the needed parts? My expertise won't allow me to perform the work myself, and my location limits access to a variety of mechanics that are familiar with these older 924s. I am confident that I can find a good shop to rebuild the engine in a larger city a couple of hours away, but I would like to be able to direct them as to exactly what I needed them to do, and provide any parts/accessories that they couldn't readily get a hold of.
I reviewed several posts that hinted at different aspects of this type of rebuild, but I couldn't find a definite parts list of what I needed to transform a 77 XH to what is essentially a XK, or a list of procedures that should be undertaken to complete such a task.
Chrenan
PostPosted: Sat Jul 19, 2008 12:57 pm    Post subject: Reply with quote
You'll need euro pistons to fit the bore of your engine (see my signature), or to fit the bore of your engine if an over-bore is deemed required on teardown (very unlikely, the 924 block can withstand an atomic explosion).
Cam is the same.
Valves in the 77 I think are smaller.
So, you'll need to cut in larger valves, so why not go bigger anyway (see my signature).
You'll have to pop the cam out to do the valves, why not replace with a hotter cam (see my signature).
I've been down the path you are heading on, but I went beyond the euro spec engine and am very, very happy with the results.
GregSC
PostPosted: Sun Jul 20, 2008 10:51 am    Post subject: Reply with quote
Thanks for the information Chrenan, very appreciated.
A couple of more questions based on this info (for you or anyone who might be able to respond)
1. Do you know of a good supplier for the Euro spec pistons? Bigger values? (I was able to locate the cam from Integral Cams)
2. Will I be able to use the stock fuel supply effectively with these modifications?
3. What kind of performance improvement can be reasonably expected from these modifications?
PORSCHEV
PostPosted: Sun Jul 20, 2008 11:15 am    Post subject: Reply with quote
It will cost you a smalla mount in extra machining but it will pay off in the end. Check this out on the for sale section. If I was doing another rebuild ........it's a great deal.
http://www.924board.org/viewtopic.php?t=26236
1978-#53 "D" track racer.
PostPosted: Sun Jul 20, 2008 12:48 pm    Post subject: Reply with quote
Also Greg, to be on the safe side you may want to consider stock rods junk, as bolts are NLA and they are not supposed to be reused. One of our members spec'd out replacements with a custom rod maker, but be ready to drop $750 for a set.
Chrenan
PostPosted: Tue Jul 22, 2008 12:03 am    Post subject: Reply with quote
I got mine from an EBay seller. If you surf www.ebay.co.uk there are a few sellers who specialize in breaking Porsches. They may not have 924 pistons listed but an email asking may turn up good results.
I had all my headwork done (includes bigger valves and cam, springs, guides, everything) by http://www.europeanmotorworks.com/contact.html. They were tuning the 924 when it was being sold new.
I am using the stock CIS. I don't have a wideband O2 sensor installed to really know what is goind on. I've never had any running issues associated with over lean or rich fueling, so I'd imagine the fueling is as accurate as the CIS is on a stock setup (which is not very accurate at all).
Haven't had my car on a dyno. The difference between the worn out car that I originally bought and the car now is night and day. But I've also gone through the suspension, brakes, etc, etc, etc...
If I had to guess, based on the cars I've kept up with, I'd guess it is comparable to a normally aspirated 944, maybe slightly better.
Rich H
PostPosted: Tue Jul 22, 2008 12:34 am    Post subject: Reply with quote
Try Porscheapart in the UK
They will be able to help I'm sure...
GregSC
PostPosted: Tue Jul 22, 2008 2:45 am    Post subject: Reply with quote
Thanks guys, all the replys have been very helpful. I appreciate your time.
PostPosted: Tue Jul 22, 2008 5:40 am    Post subject: Reply with quote
I have two sets of europistons i think, (lots of parts in the garage ). Is it worth the hassle to send them over the sea, can i get any money besides the shipping ?. Or maybe i can send them over with my folks whos flying over in august, hmm. If your intressted i can se what i have in the garage. At least one set.
Raceboy
PostPosted: Tue Jul 22, 2008 4:19 pm    Post subject: Reply with quote
Rasta, where did you get this assumption that stock rods are junk?
In fact they are very strong and we have yet to find out their upper limit! Jesper (Racing) used stock rods and to my knowledge this engine is still in full health after 4 years.
Of course, bolts are things that should be refreshed sometimes, but I've reused bolts many times and they withstand required rpm (max 7000) without a hitch. More revs aren't really necessary as both NA and 931 heads don't flow too well and VE drops like a rock after 7000 rpm even on ported head. Up to 7000 rpm you can run as much boost as you like because it's the rpm that kills the rods/bolts NOT boost. Nealry 10 years of messing with 924's and racing them, I've NEVER had a rod/rod bolt failure.
And you can't possibly justify those 750$ for NA low rev engine.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
TOM087
PostPosted: Tue Dec 02, 2008 7:41 pm    Post subject: Reply with quote
i'm thinking about doing the same thing with my martini too, and i've located a set of 9.3:1 piston and rod set for $150aud. The parts are from an 84 though, and, with my non-existent knowledge of engines, i've no idea of whether they can be used in my 77.
1977 Martini Rossi
tuurbo
PostPosted: Wed Dec 03, 2008 1:59 am    Post subject: Reply with quote
Raceboy - yeah the points you make are good ones - the rods are fine and the bolts are fine - but the supply of bolts is nil. And without rod bolts, what good are even excellent rods?
Like, what torque would you use on a bolt that's stretched or used, when using them changes everything?
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
PostPosted: Wed Dec 03, 2008 2:17 am    Post subject: Reply with quote
Yikes, sorry, I mistyped, I was referring to the bolts.
As to them, the FSM states that they are not to be reused.
I understand that many people have done it, but if I am doing a rebuild at this point in Toofah history (no more bearings), I don't want to take any chances of failure. I have a set of bearings now, but who knows when I may have another. . .
PostPosted: Wed Dec 03, 2008 3:27 am    Post subject: Reply with quote
Rod bolts can now be gotten at least. The first run from ARP should arrive sometime in January. I've order a few extras and EBS has promised to pony up for five sets to put on their shelf. Still awaiting payment from them, so if it doesn't come thru, I'll have 8 sets of rod bolts that I'll be very anxious to sell Anyway, now that ARP have the specs, we can always do another group buy in the future.
