-nick Guest
Posted: Sat Apr 13, 2002 1:37 am Post subject: |
hi all,
i threatened to post a pic of the copper gasket i used which shows how the compression leaked out:
you can see the lines from the cylinders to the outer edge where the compression pushed out.
this was a .050" thick gasket. if the stock NA is .067" and the rule of thumb is .1 compression points for every .005" then i was running ~9.6:1 with euro pistons.
as you can see, you must o-ring the block even with this little amount of compression on a copper gasket. i didn't think i would need to worry about it until the compression approached 11+, but there are just not enough headbolts to hold it in without an o-ringed head.
just an fyi, i thought it was an interesting pic. someday i'll pull the engine back out for a refresh and have it o-ringed.
-nick
[ This Message was edited by: -nick on 2002-04-13 01:39 ] |
AznDrgn Guest
Posted: Sat Apr 13, 2002 2:32 am Post subject: |
What exactly is having the head O-ringed? |
-nick Guest
Posted: Sat Apr 13, 2002 6:02 am Post subject: |
you cut a groove in the head around the circumfrence of the cylinder and insert a bead of metal in the block. so when you mate them there is a lock around each cylinder to hold the compression in.
it's not an expensive process but requires giving the machine shop your head (not such a big deal) and your block (a pita!).
this can be done vice-versa, with the groove in the block etc.
after this process you will never have another headgasket problem. some are hesistant and say that the headgasket is a safety valve keeping pistons and valves from being damaged. i've never heard of anyone having a problem on a well setup engine, it's when you start to skimp that things go wrong.
-nick |
AznDrgn Guest
Posted: Sat Apr 13, 2002 8:36 am Post subject: |
Hmm sounds like a pretty good idea. Are there any advantages to which side you do it on? Will this help for turbo charging applications when you keep the stock 8.5:1 compression? |
AznDrgn Guest
Posted: Sat Apr 13, 2002 8:37 am Post subject: |
Oh yeah and approximantly how much is it? |
-nick Guest
Posted: Sun Apr 14, 2002 3:41 am Post subject: |
i'm not sure if there is an advantage one way or another. give any auto machine shop a call, they're usually pretty interested when you start talking about things like this to them. as for price? i can't really remember what i was quoted, i'm thinking it was under $100 for all four cylinders.'
it works great for any cars that have problems with headgaskets. turbos especially.
-nick |
AppleBit
Posted: Sun Apr 14, 2002 4:03 am Post subject: |
I had the same exact problem with my copper head gasket. I am going back to the original head gasket. Less mess.
Mine lost compression as well as dripped anti-sneeze
For Sale: One copper head gasket
- Jon McCullough
Cbass Guest
Posted: Sun Apr 14, 2002 10:57 am Post subject: |
I'll buy that for a dollar!
I'd want the groove to be in the block, as theres more room to work with there. |
Richard Guest
Posted: Mon Apr 15, 2002 10:09 am Post subject: |
Just a quick question. Did you guys use any gasket cement? I thought copper head gaskets were suppose to be sealed with NAPA Hi tack sealer or GM gasket compound or equivalent. |
-nick Guest
Posted: Tue Apr 16, 2002 9:33 am Post subject: |
you can use any hylomar sealer. i talked to the manufacturer of mine and he concurred that the motor would not hold in the compression with o-ringing. a flathead ford with a gizillion headbolts yes, 924's with just 8 can't hold it in.
-nick |
AznDrgn Guest
Posted: Tue Apr 16, 2002 9:46 am Post subject: |
So there is really no point in doing it for our cars? |
-nick Guest
Posted: Tue Apr 16, 2002 10:06 am Post subject: |
sorry, the post should have said "would not hold the compression in withOUT o-ringing". if you're running high compression or lots of boost it's worth it.
-nick |
924 turbo Guest
Posted: Tue Apr 16, 2002 2:44 pm Post subject: |
Quote: | a flathead ford with a gizillion headbolts yes, 924's with just 8 can't hold it in. |
I think I figured out your problem! You forgot to put in two of the headbolts!
-nick Guest
Posted: Wed Apr 17, 2002 5:06 am Post subject: |
aha! sorry, that should be 10 headbolts. this massachusetts heat wave is really going to my head.
-nick |
Vince Ponz Guest
Posted: Wed Apr 17, 2002 8:55 am Post subject: |
I have a Eruo 85 block with 9.3 pistons if anyone is interested.
I am in NYC area |
