What about the side molding on the car? *Pictures*
Goto page Previous  1, 2, 3
PostPosted: Sat Mar 08, 2008 8:04 am    Post subject: Reply with quote
There is still a possibility that they repainted the car with side trim off and then put new side strips on. If that is the case you will have uniform paint underneith. However, not all paints are equal, and it is hard to come up with a repaint job as durable and as well bonded as the original. Therfore, if the car was repainted and new side strips applied over the paint you will have the worry that the paint may come off with the strip, being less durable than the original.
thirdgenbird
PostPosted: Sat Mar 08, 2008 8:08 am    Post subject: Reply with quote
is the trim easy to locate and relatively cheap? the section on the effected 1/4 panel is comming off a little. i may try and take it off and see what i have underneath and if it looks bad replace it with new trim.
17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel
Matt Norton
PostPosted: Wed Mar 12, 2008 12:14 am    Post subject: Reply with quote
yes you can get the stock style molding form most Porsche aftermarket retailers. try http://www.automotion.com/
My car has been repainted and was excosed to a lot of sun. the molding fell of the door reveiling a darker shade of red. Unless you are going to have the car repainted as I plan to you may not want to mess with them unless you will be recovering the are with somthing to replace it. I persnaly like the look with out but if there goes you paint if some one slames there door oppen on you. I think the thicker 944 and after market ones look better. All of the 88's I have seen have the thin style you could have them painted the same color as your car. the black cars I think look better because the molding and body are the same color.
What is up with the glass sunroof on the white car. I have never seen glass. was that an option or standard for a particlar year? does it come out like the standard remvable targa like tops that most of our cars have?
I wouldn't mind having a glass roof I could slip in when I am in the mood.
Red 1987 924S with plans for D Productions Kit
From American International Racing.
mikeycrum14
PostPosted: Fri Feb 10, 2017 2:04 am    Post subject: Reply with quote
where to buy these moldings? i like them and my car needs a few peices.
1981 924 - Alpine White
First car!
Fresh tune up, stage 3 racing clutch, stock otherwise, 5 speed trans. - SOLD
Johann
PostPosted: Fri Feb 10, 2017 2:36 am    Post subject: Reply with quote
Rose passion sells them. Have a look here
Marckowalk
PostPosted: Fri Feb 10, 2017 2:42 am    Post subject: body side moldings Reply with quote
pocketscience wrote:
I'm a firm believer in that just because it was factory doesn't necessarily mean it's worth keeping... but at the end of the day it's your car!
Those are non factory. They are too thick . Obviously after market. Automotion has complete new sets. Marc Kowalk
KODADDY
PostPosted: Fri Feb 10, 2017 10:58 pm    Post subject: Re: body side moldings Reply with quote
Holy thread resurrection batman... Either way, 9 years ago, it looked better with em off.
snakoil
PostPosted: Sat Feb 11, 2017 12:06 am    Post subject: Reply with quote
...and it still does!
1979 924 NA
Page 3 of 3
