bhowell
Posted: Sun Jan 20, 2008 4:01 am Post subject: Throttle body micro switch 924 parts number |
I have a 1980 924 Turbo and I found that one of the micro swtiches has gone bad. Any suggestions on locating a new or used one or a pair? Can anyone explain the function of each. It appears that the throttle body does not making enough contact on one to cause it to switch. Should I adjust the set screw to engage the switch. Any help would be appreciated.
On a different note, where could I find a pfd file for this model of car to locate part numbers and details.
Thanks |
Posted: Sun Jan 20, 2008 5:51 am Post subject: |
http://www.924board.org/viewtopic.php?t=17488
One switch tells the computer the throttle is closed, the other tells the computer the throttle is wide open. _________________ White 87 924S "Ghost"
