chrisoc Guest
Posted: Tue Apr 02, 2002 11:30 am Post subject: |
Please excuse my ignorance and tell me what is needed to switch from the rubber hubbed clutch assembly to the turbo style solid centered clutch assembly. Can it be done, is it a direct swap over or am I just wishful thinking? |
gohim Guest
Posted: Fri Apr 05, 2002 5:00 am Post subject: |
The 951 clutch is a different size. SACHS makes a spring center disc that you can buy from aftermarket sellers if you wnat to get away from the rubber center disc, but expect more driveline noise, and vibration then you get from a rubber center disc. |
chrisoc Guest
Posted: Fri Apr 05, 2002 8:05 am Post subject: |
thank you for the information. Some parts of this car I hope never to come into contact with, others I'm getting to know quite well. just trying to sort out all the little shakes and rattles. |
