931 Timing
bass gt
PostPosted: Mon Oct 15, 2007 11:34 pm    Post subject: 931 Timing Reply with quote
Guy's,
has anyone got a table/ graph for the ignition timing on their 931 that they could let me have a look at. Also, do you run compensations for boost [ressure, or is this integrated into the base map?
The reason i ask is that my ECU has base setings, which you can then tailor with compensation values, for boost ect. So the timing, fuel can beset, and the ecu can then automatically shift values, depending on other parameters. I would love to compare other peoples timing maps vs mine, and see if there are any improvements i can make.
Plus, it's cheaper than dyno time!!
Thanks,
Steve
Front Wheel Drive is the Devil's work.
PostPosted: Mon Oct 15, 2007 11:51 pm    Post subject: Reply with quote
I presume you aren't looking for the factory curves. If you are I have them in FSM that I can email to you.
bass gt
PostPosted: Mon Oct 15, 2007 11:55 pm    Post subject: Reply with quote
Rasta, that would be handy, but im should have been a bit more specific. I am looking for the ignition tables from those running a seperate ignition system, such as MS/MJ ect. Especially if they are running a little more boost than standard.
However, please forward the stock curves as it will give me a reference point to start.
Thanks,
Steve
PostPosted: Tue Oct 16, 2007 12:47 pm    Post subject: Reply with quote
what's your email I'll send you my map...
same as yours... distributor has no vacuum advance and no mechanical advance
base timing can be adjusted with modifiers.
Leadfoot
Raceboy
PostPosted: Sat Oct 20, 2007 3:49 am    Post subject: Reply with quote
This is the spark table I'm running on my turbocharged 924 NA (9.3:1 CR and 0.9 bars of boost).
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
