Okrasa stroker kit
Cbass
PostPosted: Mon Mar 25, 2002 7:28 am    Post subject: Reply with quote
Does anyone know where to find a stroker kit? I checked out Oettinger, who made the Okrasa kit. They're into ricing Audis now, so no help from them. If I could find a good stroker kit, I'd be quite happy.
924_fan
PostPosted: Mon Mar 25, 2002 8:51 am    Post subject: Reply with quote
Try Paeco
Cbass
PostPosted: Tue Mar 26, 2002 6:42 pm    Post subject: Reply with quote
Paeco? Do they have a website?
HRK
PostPosted: Wed Mar 27, 2002 12:37 am    Post subject: Reply with quote
email is
paeco@HiWAAY.net
They offered roughly 20% bigger displacement depending on bore. Consisting pistons, rings and crank. They need ~$1300 and exchange crank.
HRK
Cbass
PostPosted: Wed Mar 27, 2002 10:49 am    Post subject: Reply with quote
Excellent, you think I'll manage to get 400ccs?
Cbass
PostPosted: Thu Mar 28, 2002 4:11 pm    Post subject: Reply with quote
Thanks BTW, I don't know what I would do without you Porsche gods.
dwak
PostPosted: Mon Apr 01, 2002 9:26 am    Post subject: Reply with quote
HRK, how did your conversion of the '76 924 to a 931 motor go? Did you use the same drive train, etc?
dwak
HRK
PostPosted: Tue Apr 02, 2002 12:02 am    Post subject: Reply with quote
The motor conversion has been installed from -86. I utilizes original 4-speed drivetrain with modified disk to attach smaller splines on clutch. Somewhere during several clutch job, modified disc was lost and now there is disc from diesel audi, which seems to hold. Gearbox seems to hold pretty well too, it's been rebuilt only once as far as I know. Brakes are from -84 944.
dwak
PostPosted: Tue Apr 02, 2002 3:22 am    Post subject: Reply with quote
HRK, That seems like a relatively simple and clever instalation vs drive-train swaps and, I believe, the 4 SPD trannie is a strong one. You could probably get away with just beefing up the front brakes too. You must surprise a lot of people on the highway. I guess the top speed would be about the same, though.
dwak
HRK
PostPosted: Fri Apr 05, 2002 12:44 am    Post subject: Reply with quote
Not too much surprises on the highway.
The car doesn't anymore hide its potential. Intercooler and piping is visible. It's located just under/ behind front bumper. GTS lights and lower spiler tells the tale too.
Stock turbo runs out of breath around 6300 rpm, but boy does it get there fast!
