copper headgasket info
-nick
Guest
PostPosted: Sat Apr 13, 2002 2:37 am    Post subject: Reply with quote
hi all,
i threatened to post a pic of the copper gasket i used which shows how the compression leaked out:
you can see the lines from the cylinders to the outer edge where the compression pushed out.
this was a .050" thick gasket. if the stock NA is .067" and the rule of thumb is .1 compression points for every .005" then i was running ~9.6:1 with euro pistons.
as you can see, you must o-ring the block even with this little amount of compression on a copper gasket. i didn't think i would need to worry about it until the compression approached 11+, but there are just not enough headbolts to hold it in without an o-ringed head.
just an fyi, i thought it was an interesting pic. someday i'll pull the engine back out for a refresh and have it o-ringed.
-nick
[ This Message was edited by: -nick on 2002-04-13 01:39 ]
AznDrgn
Guest
PostPosted: Sat Apr 13, 2002 3:32 am    Post subject: Reply with quote
What exactly is having the head O-ringed?
-nick
Guest
PostPosted: Sat Apr 13, 2002 7:02 am    Post subject: Reply with quote
you cut a groove in the head around the circumfrence of the cylinder and insert a bead of metal in the block. so when you mate them there is a lock around each cylinder to hold the compression in.
it's not an expensive process but requires giving the machine shop your head (not such a big deal) and your block (a pita!).
this can be done vice-versa, with the groove in the block etc.
after this process you will never have another headgasket problem. some are hesistant and say that the headgasket is a safety valve keeping pistons and valves from being damaged. i've never heard of anyone having a problem on a well setup engine, it's when you start to skimp that things go wrong.
-nick
AznDrgn
Guest
PostPosted: Sat Apr 13, 2002 9:36 am    Post subject: Reply with quote
Hmm sounds like a pretty good idea. Are there any advantages to which side you do it on? Will this help for turbo charging applications when you keep the stock 8.5:1 compression?
AznDrgn
Guest
PostPosted: Sat Apr 13, 2002 9:37 am    Post subject: Reply with quote
Oh yeah and approximantly how much is it?
-nick
Guest
PostPosted: Sun Apr 14, 2002 4:41 am    Post subject: Reply with quote
i'm not sure if there is an advantage one way or another. give any auto machine shop a call, they're usually pretty interested when you start talking about things like this to them. as for price? i can't really remember what i was quoted, i'm thinking it was under $100 for all four cylinders.'
it works great for any cars that have problems with headgaskets. turbos especially.
-nick
AppleBit
PostPosted: Sun Apr 14, 2002 5:03 am    Post subject: Reply with quote
I had the same exact problem with my copper head gasket. I am going back to the original head gasket. Less mess.
Mine lost compression as well as dripped anti-sneeze
For Sale: One copper head gasket
- Jon McCullough
Cbass
Guest
PostPosted: Sun Apr 14, 2002 11:57 am    Post subject: Reply with quote
I'll buy that for a dollar!
I'd want the groove to be in the block, as theres more room to work with there.
Richard
Guest
PostPosted: Mon Apr 15, 2002 11:09 am    Post subject: Reply with quote
Just a quick question. Did you guys use any gasket cement? I thought copper head gaskets were suppose to be sealed with NAPA Hi tack sealer or GM gasket compound or equivalent.
-nick
Guest
PostPosted: Tue Apr 16, 2002 10:33 am    Post subject: Reply with quote
you can use any hylomar sealer. i talked to the manufacturer of mine and he concurred that the motor would not hold in the compression with o-ringing. a flathead ford with a gizillion headbolts yes, 924's with just 8 can't hold it in.
-nick
AznDrgn
Guest
PostPosted: Tue Apr 16, 2002 10:46 am    Post subject: Reply with quote
So there is really no point in doing it for our cars?
-nick
Guest
PostPosted: Tue Apr 16, 2002 11:06 am    Post subject: Reply with quote
sorry, the post should have said "would not hold the compression in withOUT o-ringing". if you're running high compression or lots of boost it's worth it.
-nick
924 turbo
Guest
PostPosted: Tue Apr 16, 2002 3:44 pm    Post subject: Reply with quote
I think I figured out your problem! You forgot to put in two of the headbolts!
-nick
Guest
PostPosted: Wed Apr 17, 2002 6:06 am    Post subject: Reply with quote
aha! sorry, that should be 10 headbolts. this massachusetts heat wave is really going to my head.
-nick
Vince Ponz
Guest
PostPosted: Wed Apr 17, 2002 9:55 am    Post subject: Reply with quote
I have a Eruo 85 block with 9.3 pistons if anyone is interested.
I am in NYC area
