augidog
Posted: Mon Jul 30, 2007 11:25 am Post subject: old trans -new oil question |
I finally got the trans off the parts car. The coupling was rusted. Someone said in another post to just use a extension ratchet and a hammer-That did the trick once I got a good corner shot to hit
Before I sink some cash into Swepco fluid I filled it with some wall mart 85-145 weight gear oil. This is in case the trans is bad and to give it a good rinse.
I never saw 85-145 weight fluid before. I guess it means up to and all in between. Is it ok to run for a week or two with this general fluid? The fluid was low and dirty on the parts car. No leaks that I can see. _________________ 1978 924 95 mile daily driver.
Audi TB/POR174M/High Flow Cat/2.25" exhaust
I knew that positive thinking thing wouldn't work. |
Mike924
Posted: Mon Jul 30, 2007 5:40 pm Post subject: |
The Porsche recommended viscosity range is 80 - 90 iirc. The 85 - 145 multigrade is correct at the bottom end, which is good for when the gearbox is cold. The 145 top-end will make it a bit heavy when it's warm, so you might have a bit of trouble attempting fast changes and your gas mileage might go up a bit, but overall I don't seem that any harm will be done.
Still, change to the correct grade as soon as you can. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
1993 Porsche 968 Coupe, Midnight Blue, 6 spd
'There is no substitute for a little grease under your fingernails.' - Chrenan, 924board.org |
John Brown
Posted: Thu Aug 02, 2007 9:29 am Post subject: |
times 2
Common misconception that heavier oil is better. Not true for either engines of transmissions.
The idea of using inexpensive stuff for a short time to flush is good. Using the wrong viscosity not so good. But not fatal. _________________ John
80 931 - #931 44Cup
99 Escalade - tows track cars
gone but not forgotten: original 924.org car - 82 |
