Headlight motor
jshort75
PostPosted: Sun Aug 26, 2001 6:54 pm    Post subject: Reply with quote
Guys I get erratic operation from my headlight motor. I took it apart and cleaned and relubed the gearbox and put it back together. Still have erratic operation. What's the scoop? I checked the headlight switch and the wiring at the motor plug in (where others have experienced problems). Other than going to fixed lights what are some other solutions??
PostPosted: Sun Aug 26, 2001 8:37 pm    Post subject: Reply with quote
connectors, bad connectors, very bad connectors.
I had to replace the 6-way connector behind the fuse block. A bitch of a job but it made all my headlight motor problems go away.
larso
PostPosted: Mon Aug 27, 2001 4:55 am    Post subject: Reply with quote
check switch.
