bass gt
Posted: Tue Jul 10, 2007 7:55 am Post subject: Intercooler Efficiency*Pics* |
Well Guy's,
After much thought and research, i think i have managed to fabricate a low pressure draw through system for the front mounted 951 IC. Having looked at the air pressure diagrams posted here previously, and doing a bit of parallel research, i think i've hit the jackpot. I had this set up for the Castle Combe race, which i won, despite very nasty weather and being totally outgunned in the HP department. It seems to have made the mid range much fatter, so the engine is not such a hand grenade in it's power delivery. I have fitted a pre IC temp sensor as well as having a post IC sensor, so i will be able to give some real world figures as to temperature drops across the IC in real world conditions.
All i can say is that at the moment, going by the seat of the pants power meter, it seems to work a charm.
Enjoy,
Steve
[/img]
Posted: Tue Jul 10, 2007 8:01 am Post subject: |
Very nicely done! They make very similar hoods for the evo and rx7s, so I would be willing to bet that you definately helped the cause. _________________ [This Space For Rent] |
bass gt
Posted: Tue Jul 10, 2007 8:05 am Post subject: |
Cheers Flosho,
next race is on the 21st, so i will be able to get some meaningful data. Will be interesting i guess. Might rig up a big fan and light some cigarettes and do some ad hoc wind tunnel research
Steve |
Posted: Tue Jul 10, 2007 8:54 am Post subject: |
<droool>
I am in lust with your car!!! Makes mine look like a total beater!
Doh! It is!!!  _________________ Vaughan Scott
Posted: Tue Jul 10, 2007 9:08 am Post subject: |
looks very very purdy,
is it bad that I am tempted to get a ticket to england and watch your next race? _________________ 3 928s, |
bass gt
Posted: Tue Jul 10, 2007 9:17 am Post subject: |
| Lizard wrote: | looks very very purdy,
is it bad that I am tempted to get a ticket to england and watch your next race? |
Bad Lizard, VERY BAD Lizard!!
well, if you ever find yourself this side of the pond, and are at a loose end, come and checkout Simsport and myself campaigning the old girls. Actually, there are quite a few 24's in the Championship, in all classes, although i seem to be the only mug who thought it would be a great idea to pitch a 24T against the big boys. Still, I've always loved an unfair fight
However, once i get some meaningful data, this might be a mod worth looking in to, even for a road car. Get a spare hood and give it a whiz.
Steve |
Chrenan
Posted: Tue Jul 10, 2007 10:26 am Post subject: |
Looks amazing, what a novel idea on a 924 turbo, I don't even think I've ever seen that on a 951, nevermind a 931. _________________ 1987 951 - M193 Version for Japan |
Posted: Tue Jul 10, 2007 10:34 am Post subject: |
Is all the intake air from the 4 plastic vents? _________________ White 87 924S "Ghost"
bass gt
Posted: Tue Jul 10, 2007 10:38 am Post subject: |
| Paul wrote: | | Is all the intake air from the 4 plastic vents? |
Yes, but the IC has a scoop/shroud around the front of it to funnel the air into it. as per Mr. Bell's book, apparently an IC only needs an air inlet 1/4 the size of it's frontal area.
The scoop extends forward to about 2 inches from the 4 nose scoops, so the air is fairly forced through.
Steve |
Posted: Tue Jul 10, 2007 10:55 am Post subject: |
I've thought about using a set up similar to this after seeing nicks car with the intercooler in front of the engine. _________________ [This Space For Rent] |
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Tue Jul 10, 2007 11:10 am Post subject: |
OH MAN...
that is sexual... _________________ '86 944 |
Posted: Tue Jul 10, 2007 11:50 am Post subject: |
Nice! _________________ White 87 924S "Ghost"
endwrench
Posted: Tue Jul 10, 2007 12:14 pm Post subject: |
Beauty!! I even like the way it looks from the outside. Must be a pretty nice low pressure area right there. Can't wait to see the temp readings.
bass gt
Posted: Tue Jul 10, 2007 12:38 pm Post subject: |
| endwrench wrote: | Beauty!! I even like the way it looks from the outside. Must be a pretty nice low pressure area right there. Can't wait to see the temp readings.
Todd |
As soon as i get some meaningful data i'll post it up |
-nick
Posted: Wed Jul 11, 2007 1:11 am Post subject: |
You really do some expert fab work! The only trouble with trying to duplicate it for a road car is messing with the hood latch / pins. Otherwise, it looks like an excellent advantage!
I'll check into adding an extra intake air temp sensor on my turbo outlet to see how mine compares. I think I typically run around 40F over ambient temp or so.
You're getting to the point where I can't even think of any tricks to add to your ride! Truly a beauty! _________________ 1980 931S
1991 964 C4 Cabriolet |
