Skimdude Guest
Posted: Tue May 14, 2002 9:38 pm Post subject: |
I am always listening to to sound of my engine if it sounds normal. About a year ago I heard my engine ticking at 3000 rpm or higher. I suppose that the ticking is caused by the injectors. Right now I hear the engine ticking at 1000 rpm or higher. Could it be that my injectors are dirty?
I have never cleaned anything in 2 year. Just cleaned/replaced engine (car) fluids.
Could someone help me out?
Skimdude Guest
Posted: Tue May 14, 2002 9:44 pm Post subject: |
P.S. The ticking isn't that loud, but I'm a careful listener. It is hearable while driving though. You can hear the ticking very clearly with the engine hood open.
The ticking bothers me because I couldn't hear it at 1000 rpm before.
Joined: 29 Jul 2001 Posts: 8372 Location: Royal Oak, MI, USA
Posted: Wed May 15, 2002 12:12 am Post subject: |
Yeah, I seem to recall that the 924S has hydraulic lifters - unlike the 924, whose mechanical lifters always click'n'clack. Therefore it's most likely the injectors. Try running one or two bottles of Chevron FI cleaner with Techron through - Porsche actually recommends it by name. It's always a good idea, at least one bottle a year...
'79 924 #77 ITB racecar
Skimdude Guest
Posted: Wed May 15, 2002 12:41 am Post subject: |
What kind of oil would you suggest for a 924S? 10W40 or 15W40?
I use 10W40, could that be too thin?
Thanx for your info by the way.
Alleycat Guest
Posted: Wed May 15, 2002 12:52 am Post subject: |
Im using 5w50 Its recomended by my local Porsche Center
numbers Guest
Posted: Wed May 15, 2002 9:02 am Post subject: |
It sounds more to me that your hydraulic lifters are ticking. Can be caused by low oil pressure, or by dirty oil. However, the most common cause are the lifter are reaching the end of their life span. |
Skimdude Guest
Posted: Wed May 15, 2002 7:49 pm Post subject: |
What could cause the ticking of the lifters? Is it difficult/expensive to fix it?
The oil pressure is ok by the way, oil isn't too dirty either.
