gaytrey1987
Joined: 09 Jun 2007 Posts: 7 Location: Springfield, MO / Bentonville, AR
Posted: Tue Jun 19, 2007 12:57 pm Post subject: Irratic Oil Pressure Light *blinkage?* |
Are oil pumps a part that are prone to defect in the 2.0 liter Porsche motor? I think it may be a wiring glitch, but I'm not sure... my car has had a fresh oil change and filter, is filled to max, and I'm getting a lot of blinking out of my oil pressure light while at rpms below 3000 (most of the time). The oil pressure gauge is also being really jumpy.
Input is appreciated.
Will S. _________________ Will S.
1991 Dodge Stealth R/T AWD Twin Turbo
1990 Dodge Grand Caravan Twin Turbo
1981 DeLorean DMC-12 Gas-Flap Hood
1978 Porsche 924
A wise 924 owner has two: one for parts, and one that starts. |
Posted: Tue Jun 19, 2007 1:23 pm Post subject: |
Check grounds, battery to body, motor to body, and ground cluster under dash.
Is this the soaking wet car? _________________ Toofah King Bad
Mike924
Posted: Tue Jun 19, 2007 5:14 pm Post subject: |
^+1 + check connection to oil pressure sender at the back of the cylinder head.
BTW, Will, you've just lost your geek credentials by spelling 'erratic' wrong!  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
1993 Porsche 968 Coupe, Midnight Blue, 6 spd
'There is no substitute for a little grease under your fingernails.' - Chrenan, 924board.org |
Ozzie
Posted: Tue Jun 19, 2007 5:21 pm Post subject: |
Usually wiring or bad grounds. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Posted: Tue Jun 19, 2007 11:43 pm Post subject: Re: Irratic Oil Pressure Light *blinkage?* |
| Quote: | | Are oil pumps a part that are prone to defect in the 2.0 liter Porsche motor? |
The oil pumps seem to be pretty robust. Some have had to deal with the built-in pressure relief valve, but the pumps themselves are very good (usually ).
With the light blinking, I'd suspect maybe some of the foil insulation on the firewall is to close to the sender at the back of the cyl head. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Slam
Joined: 07 Jan 2005 Posts: 1689 Location: Wainwright, Alberta, Canada
Posted: Wed Jun 20, 2007 2:31 am Post subject: |
Sounds like rod bearings... But make all the checks these guys have suggested first. Can you plumb in an oil pressure gauge apart from the one in-dash? _________________ '84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably |
Joined: 29 Jul 2001 Posts: 9076 Location: Royal Oak, MI, USA
Posted: Wed Jun 20, 2007 3:33 am Post subject: |
I'd fully expect it's electrical. _________________ Vaughan Scott
Posted: Wed Jun 20, 2007 10:47 am Post subject: |
Probably electrical, but it's a 5 minute job to remove and clean the pressure relief valve, so go for it. _________________ White 87 924S "Ghost"
geddes66
Joined: 10 May 2003 Posts: 129 Location: Bakersfield CA
Posted: Sat Jun 23, 2007 9:31 am Post subject: |
What is your pressure doing at said 3000 RPM avraging the jumps?
Does it "blink" the same both cold and hot?
Please post removal procedures for pressure relief valve. _________________ The Porsche is now my son's, my car is cooler, slower but cooler. |
Posted: Sat Jun 23, 2007 11:14 am Post subject: |
It's held in place by the large cover (looks like a large nut) on the end of the oil pump. Its to the left (when standing over the open engine bay) and sligthly lower than the center of the front pulley.
Just unscrew it and the spring and piston will fall out (catch it). Clean the parts and the bore and put it back together. _________________ White 87 924S "Ghost"
gaytrey1987
Posted: Sun Jun 24, 2007 8:21 pm Post subject: |
| Slam wrote: | | Sounds like rod bearings... But make all the checks these guys have suggested first. Can you plumb in an oil pressure gauge apart from the one in-dash? |
RIP 1978 Porsche 924
Cause of death: #3 cylinder connecting rod bearing
Engine gave no sign of death aside from a blinking oil light and erratic oil pressure. The car croaked on the side of the road in Bentonville, Arkansas on my way back to the office from lunch. She started missing all of a sudden, and a block later, she coasted klutzily into a ditch where she shuddered, sputtered, and died. We pulled it back to the house, it wouldn't start with the starter, but we did get it to crank and remain running from pull starting it, dead miss on #3, engine eventually siezed, and is being taken out to be re-built or to be transplanted with a Toyota 22RE-T. I haven't decided which will be more difficult: Rebuilding a porsche engine, or transplanting the porsche wiring and engine with that from an 89 Toyota Pickup Truck..... eek. I hate restoring cars on a budget. |
Mike924
Posted: Mon Jun 25, 2007 12:26 am Post subject: |
What makes you think it's the con rod bearing?
A broken rod bearing wouldn't cause all the symptoms you mentioned. Although it does sound pretty terminal, all told.  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
