tomcooper
Joined: 17 Feb 2004 Posts: 301 Location: Waterloo, Nebraska
Posted: Tue Apr 03, 2007 10:57 am Post subject: Never trust your jack stands |
Here is a post to the 914 World Board that should give each of us a reason to pause to take a look at how we work on our cars. Mike is a very luck guy.
http://www.914world.com/bbs2/index.php?showtopic=70117&st=
Tom _________________ Casper and Big Red, both 1980 NA
Black Bart, 1990 944 S2 Cab |
Chrenan
Posted: Tue Apr 03, 2007 11:36 am Post subject: |
Yikes!!!
I am paranoid about this sort of thing. I use four 6 ton jack stands, then I put blocks I made out of 2 by 8 lumber under each wheel as an extra precaution if one of the stands fail. If a wheel is off on the front, I put the lumber under the cross member. If a wheel is off on the rear, I leave the lumber under the brake drum.
I like the six ton stands as they can get the car higher, with the added benefit that if the ratchet on the stand does fail, even at the lowest setting I still fit under the car. _________________ 1987 951 - M193 Version for Japan |
endwrench
Posted: Tue Apr 03, 2007 11:43 am Post subject: |
Scary  _________________ '79 924NA. Rebuilt 9.5:1, MSDS header, Mega Squirt Injection, MJLJ-EDIS Ignition, 1.6L Whipple Charger and Intercooler, 10lbs Boost, 944 Trans, Custom HD Clutch.
Hoboceratops
Posted: Tue Apr 03, 2007 1:45 pm Post subject: |
Oh great... this is all I'm going to be thinking about while I'm checking/dropping transmission.
On the plus side, I'll be very careful on positioning the car on the stands.
Down side? Well... I should probably just keep a spare pair of pants handy. _________________ 1987 924S: Very much in love with it, even if it's all finnicky |
geddes66
Joined: 10 May 2003 Posts: 129 Location: Bakersfield CA
Posted: Tue Apr 03, 2007 1:48 pm Post subject: |
Myquestion is: Exactly what part of the jackstand "gave way"?
I have knocked the car off the jack stand while under it fighting to get a trans in(out?). Steel/steel don't have a good friction co-efficient. but it only slipped off the rear torsion bar housing and the car only fell 3" before the stand hung up on the sheet metal. Those "OSHA approved" stands are still crap if teh top is too flat. Still scary.  _________________ The Porsche is now my son's, my car is cooler, slower but cooler. |
Mike924
Posted: Tue Apr 03, 2007 5:33 pm Post subject: |
Frightning!
I'm sure we all take the sort of precautions Chrenan metioned there, but in this case, it seems the stand itself failed. All you can do about that, I guess, is regularly check the condition of the weld joints, etc; but how many of us do that...? _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
1993 Porsche 968 Coupe, Midnight Blue, 6 spd
'There is no substitute for a little grease under your fingernails.' - Chrenan, 924board.org |
Ozzie
Posted: Tue Apr 03, 2007 6:29 pm Post subject: |
Looks like its a rachet type jack which I wouldnt use.
Pin type jacks are far safer.
I also leave the jack up as well as the stands, with all/most of the weight on the stands. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
PORSCHEV
Posted: Tue Apr 03, 2007 7:27 pm Post subject: |
I use 6 ton stands as well... I also always leave the jack under the car with a slight pressure holding up on the car. I work in my shop alot by myself with no one that would hear me if something went wrong... just extra precautions. _________________ 1976 924
1978-#53 "D" track racer. |
Mike924
Posted: Tue Apr 03, 2007 7:36 pm Post subject: |
| Ozzie wrote: | | I also leave the jack up as well as the stands, with all/most of the weight on the stands. |
Ditto,
but my latest set of stands are the ratchet type. *gulp!*  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Tue Apr 03, 2007 8:15 pm Post subject: |
too bad about the guy.....i have a big hole in my garage..so i dont have to lift the car up many times...but when i do..i use big wood logs to jack up the car. _________________ Supercharger and EFI kits
https://www.the924.com |
tomcooper
Posted: Tue Apr 03, 2007 10:24 pm Post subject: |
If you read through the posts carefully, Mike seems to think that the reason the jackstand failed was that he accidentally hit it while trying to remove the engine mounting bar (teeners have a long bar that goes across the "front" of the engine and mounts to either side) and that even under load the rachet type stands can slip down.
That being said, I am no fan on the OSHA type stand with the flat top. There is much less of a chance that will fail if accidentially bumped, but the flat surface is more likely to slip off a round mounting point. I like the secondary back up of a tire or other large object in addition to the jacket stands.
Raceboy
Posted: Tue Apr 03, 2007 10:43 pm Post subject: |
Never had a jack stand failure before but I've NEVER trusted them also. Just put a wheel or whatever under the car just for precaution. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
924guy
Posted: Wed Apr 04, 2007 2:55 am Post subject: |
i had a jackstand collapse on me many years ago, fortunately i also had a hydrolic jack still locked and under the car which saved me from getting crushed too badly. i think its a rare occurance though, and most of them that do give way, are due to improper placement or unstable ground (like a sandy surface.) even now though, i still not only use the six ton stands, properly locked and placed, but also block the wheels if i only have one end of the car up, keep the hydrolic jack in place and locked, and also put a spare wheel or cinder block under the frame rails as well. once the car is up and secure, i actaully wiggle it a bit to make sure theres no slippage, then and only then do i go to work under the car.
might be a bit of overkill, but you can never be too safe... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
-nick
Posted: Wed Apr 04, 2007 3:26 am Post subject: |
This is a good reminder. I know that I tempt fate on occasion. I have the ratchet-type stands, but they are 4-legged and look like they could hold up a tank. Placement is usually more of the problem.
** The wriggle test should always be a requirement before getting under the car! _________________ 1980 931S
1991 964 C4 Cabriolet |
Stu2j
Joined: 03 Nov 2002 Posts: 1285 Location: Virginia Beach, VA
Posted: Wed Apr 04, 2007 4:11 am Post subject: |
I am completely lost.... (probably no surprise there)
Even if my jackstand(s) were to "collapse", the height of the stand itself would prevent me from getting crushed as the stand is taller than the width of my head. I thought they were intentionally designed that way.
I'm just not getting how this happened...  _________________ -Stu
924 owner since 1988
924S owner since 2002
Click here to view them: |
