Posted: Wed Mar 18, 2015 5:32 pm Post subject: |
Wow !
You should not modify this car. Sell it to someone that wants to keep it original and get a later model. _________________ SUPERCHARGED Ruby-sh 924 |
chris79
Posted: Wed Mar 18, 2015 9:21 pm Post subject: |
Why ? I read that sway bar was optional in 924 na before '78 |
chris79
Posted: Wed Mar 18, 2015 11:18 pm Post subject: |
Can anyone post some photos of bottom 924 na ? |
Posted: Wed Mar 18, 2015 11:21 pm Post subject: |
you should make a new topic for your car, moderator should move all these posts to your topic...we are polluting a how-to topic. _________________ SUPERCHARGED Ruby-sh 924 |
chris79
Posted: Thu Mar 19, 2015 12:10 am Post subject: |
if I create a new post they tell me read how to, I'll have to write somewhere ? |
Chrenan
Posted: Wed Jun 10, 2015 7:20 am Post subject: |
morghen wrote: | you should make a new topic for your car, moderator should move all these posts to your topic...we are polluting a how-to topic. |
I'm disgusted to have come back and seen the mess made of my how-to thread. This is how content contributed by senior members is treated? I demand retribution. _________________ 1987 951 - M193 Version for Japan |
Brockoli
Joined: 06 Feb 2007 Posts: 621 Location: Edmonton, Alberta, Canada
Posted: Wed Jun 10, 2015 7:50 am Post subject: |
Rare Chrenan sighting!!!! O no, I'm also polluting the thread  _________________ '80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
25% of a '87 944 Chumpcar http://straightpipe.ca/forums/showthread.php?t=2454
'79 924 Sebring Edition(Sitting) |
XLR8
Joined: 30 Mar 2016 Posts: 131 Location: Byron Bay, Australia
Posted: Sat Mar 10, 2018 9:17 am Post subject: Finally put a rear sway on my '82 NA. |
I found a pair of used 944 S2 Sways (27mm front, 18mm rear) and have only managed to get the 18mm rear bolted in so far.
The car has a 21mm front installed from factory (and for the moment, still does).
She's gone from understeering on power in tight turns to quite dramatic oversteer (tight and medium turns) - even with <125bhp! She would be a handful in the wet!
I plan to install the 27mm front, which I think will even things out a bit. My seat of the pants thinks that a 16mm rear would be an excellent match for the standard 21mm front. _________________ '81 Porsche 924 NA
'89 Eunos Roadster NA6
'06 Landcruiser HDJ100 |
XLR8
Posted: Wed Apr 11, 2018 9:14 pm Post subject: |
Finally got the 27mm sway bar on the front (18mm already installed in the rear). I installed some Poly main bushings at the same time.
What a transformation! Steering is quicker, muuuuuch flatter cornering, and cornering potential is way faster. Highly recommended. _________________ '81 Porsche 924 NA
