Posted: Wed Oct 29, 2008 7:45 pm Post subject: |
Excellent info Peter, thank you.
Now when the factory sells out it will be easier to make your own. Or, if like me consider $45 for a bent bit of 50 x 3 flat bar with 2 holes a rip can avoid the factory ones. Thought they were like $22 but thats US and a big difference now.
Is there any logical reason why the legs are reduced to 30mm? Quicker to weld? less heat? naa. Oh the length of the legs please Peter? Unless there`s good purpose to grinding 50mm to 30 will use 50 bar. Easier to set up square when welding and stronger than 60% of the same weld bead.
We need to get the precise location and angle that these are attached to the torsion bar tube from someone who has them factory fitted. |
924guy
Posted: Thu Oct 30, 2008 2:02 am Post subject: |
took some basic measurement from the 84 944, in inches, pics follow:
some may be a bit difficult to see, i just put a straight edge ruler up against various points to see where the center and edges are..let me know if more detail is needed, i can always crawl under there again with in the next few weeks until i finsih stripping it and dispose of the carcass.. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Joined: 29 Jul 2001 Posts: 2742 Location: Sydney, Australia
Posted: Thu Oct 30, 2008 10:44 am Post subject: |
I've updated the pic with the length of the legs. The height of the mount from highest point to the end of the legs is 44mm. _________________ 1979 924 (Gone to a better place)
Posted: Fri Oct 31, 2008 12:39 pm Post subject: |
I just ran across this on my PC that might be helpful:
Posted: Fri Nov 07, 2008 10:36 am Post subject: |
leadfoot wrote: | Whiteline sell brackets to mount the rear swaybar - KU3 universal fits the best, and you can use 14mm poly bushes with it... |
Quote from local AutoOne store:
KU3 ~AUD$60
W0400-14 ~AUD$20
AUD$80 - job done.
Sounds like that's considerably cheaper than a stock setup.
Peter_in_AU wrote: | The prices were slightly higher due to the Aussie dollar now being worth two flat rocks rather than three; 113 411 333 (clamp) AU$9.50 each, 477 501 095 (clip) AU$44.65 each but the real shock was the rubber bushes (477 411 313 C) at AU$37.70 each |
69 911 |
Posted: Fri Nov 07, 2008 4:53 pm Post subject: |
Cool. Post some pics when you get them. _________________ 1979 924 (Gone to a better place)
Posted: Wed Nov 26, 2008 1:43 pm Post subject: |
Peter_in_AU wrote: | Cool. Post some pics when you get them. |
Came to AUD$76.20. They didn't have the whiteline bushes, so got Nolathane instead - red instead of white - whatever...
Now all I need is that rear sway... Dan...
69 911 |
Joined: 01 Oct 2004 Posts: 15511 Location: Woodstock IL
Posted: Wed Nov 26, 2008 2:04 pm Post subject: |
It just went into a big long box with Peter's torque tube this evening
I'm still trying to track down one early set of spindles and hubs. Otherwise, the only thing left to do is build the crates for the two transaxles. I started work tonight on the parts lists, and should have that done by tomorrow. After our Thanksgiving Holiday this weekend, I should be ready to weigh everything and schedule the drop off at the forwarders  _________________ 75 Fiat X1/9 | 80 US 931 '941' | 78 Poli-Form |
Posted: Fri Aug 21, 2009 9:09 pm Post subject: |
pocketscience wrote: |
G. |
Have you fitted these yet Gav?
Or at least tried them?
Don`t know about yours, but my torsion bar carrier measures 90mm dia.  |
Posted: Fri Aug 21, 2009 9:36 pm Post subject: |
Ugh. No, not yet...  _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
Posted: Fri Aug 21, 2009 11:04 pm Post subject: |
leadfoot wrote: | Whiteline sell brackets to mount the rear swaybar - KU3 universal fits the best |
CORRECTION: Does not f*cking fit.
Grrrr, sh1t, bugger, f*ck.  _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
9XX Girl!
Joined: 20 Sep 2009 Posts: 1617 Location: Cornish Riviera SW England
Posted: Tue Jun 29, 2010 5:14 am Post subject: Re: How to Install a Rear Sway Bar on a 924 without one |
Chrenan wrote: |  |
So..... does the exhaust have to come off or can you get the Anti-roll bar in position without removing the exhaust? _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY |
Rich H
Posted: Tue Jun 29, 2010 5:21 am Post subject: |
You can wrestle it into place OK with zorst on. _________________ 1994 Lotus Esprit S4 - Work in progress...
9XX Girl!
Posted: Tue Jun 29, 2010 5:26 am Post subject: |
Thanks mate  _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
isuras2
Posted: Tue Jun 29, 2010 1:50 pm Post subject: |
Is it possible for the brackets be welded to the torsion tube with the tube mounted in the car? _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
