How to Install a Rear Sway Bar on a 924 without one
PostPosted: Mon Jun 16, 2008 1:46 pm    Post subject: Reply with quote
Yikes, better dremel off that excess boltage.
Chrenan
PostPosted: Mon Jun 16, 2008 2:18 pm    Post subject: Reply with quote
Tiny wrote:
Thank-you Chrenan and Smoothie! Worked like a charm.
I've said it before and I'll say it again. What a great site full of great people!
Tiny
Hey, that looks familiar! Nice work!
Yeah, you could cut off the extra part of the u-bolt sticking out to make it pretty, but still, nice job.
Rich H
PostPosted: Mon Jun 16, 2008 6:03 pm    Post subject: Reply with quote
Should have said, I too have done this thanks to this guide, thanks!
Cheers
Rich
Chrenan
PostPosted: Mon Jun 16, 2008 11:30 pm    Post subject: Reply with quote
Wow, I should open a business in the UK writing how-to's for the 924, I could have upwards of 2 customers!
Glad it helped guys.
Rich H
PostPosted: Mon Jun 16, 2008 11:48 pm    Post subject: Reply with quote
I'm sure you could do better than Haynes did!
PostPosted: Fri Oct 17, 2008 2:22 pm    Post subject: Reply with quote
ZOUNDS! Just stumbled across something interesting in the early 944 PET. . .you can buy new rear sway bar brackets from Porsche, ready to weld on!
477 501 095 - Mounts (2)
133 411 333 - Retaining bows (2)
I just ordered these through my local Porsche agent. There are 29 of the mounts (477 501 095) in the warehouse in Germany (27 now that I've ordered 2) and they quoted me AU$29 each. They have the 133 411 333 retainers in Melbourne (didn't ask how many) and they are AU$9 each.
PostPosted: Fri Oct 17, 2008 9:55 pm    Post subject: Reply with quote
For those of you wanting the 5-lugs down under, it's the retaining bows you'll want to pick up. Especially at that price.
PostPosted: Fri Oct 24, 2008 2:40 pm    Post subject: Reply with quote
Arrived today. Here are what the factory parts look like in the flesh:
From left to right we have 113 411 333, 477 411 313 C and 477 501 095.
The prices were slightly higher due to the Aussie dollar now being worth two flat rocks rather than three; 113 411 333 (clamp) AU$9.50 each, 477 501 095 (clip) AU$44.65 each but the real shock was the rubber bushes (477 411 313 C) at AU$37.70 each (the factory rubber bushes for the front swaybar were less than $10 each).
PostPosted: Sat Oct 25, 2008 4:55 am    Post subject: Reply with quote
Do you have to have (477 501 095) welded to the carrier bar or w/e its called?
PostPosted: Sat Oct 25, 2008 5:01 am    Post subject: Reply with quote
Torsion carrier. And the answer is "yes".
PostPosted: Sat Oct 25, 2008 11:51 am    Post subject: Reply with quote
I was thinking about that because welding around that area of the car could be potentially dangerous with a 30 year old fuel system right beside you.
You could probably weld nuts or tubes onto the sides on the `095 part and then bolt it on like Chrenan did with the C-clamp.
!tom
PostPosted: Tue Oct 28, 2008 4:58 am    Post subject: Reply with quote
Ahem. I hope this is a case of different terminology, but around these parts, it's a U-bolt, and Chrenan used a muffler clamp (that's a U-bolt and the other doohickey that makes the other half of the circle).
A C-clamp is NOT for use as a permanent part of a car, unless you're one of these dreaded P/O's everyone loves to complain about!
78 924 NA
5-lug
PostPosted: Tue Oct 28, 2008 7:07 am    Post subject: Reply with quote
Yeah that's what I really meant, what he used
PostPosted: Tue Oct 28, 2008 9:36 pm    Post subject: Reply with quote
Peter, any chance of taking the dimensions of the weld on bracket?
Think its Superpro that make urethane mounts with various IDs and their own saddle clamp. Am running with that on the front and it doesn`t look too difficult to literally knock up something similar out of 3mm plate.
PostPosted: Wed Oct 29, 2008 12:06 pm    Post subject: Reply with quote
Here you go Roger. Hope this helps. They're both 3mm thick.
I got some Superpro A-arm bushes good price haven't fitted them yet.
If you want more accurate measurements I can post a set of the clamps to you. It's going to be a while before I'm ready to fit them.
Page 2 of 5
