tomcooper
Joined: 17 Feb 2004 Posts: 301 Location: Waterloo, Nebraska
Posted: Tue Feb 27, 2007 1:25 pm Post subject: Deck Height |
Does anyone have a number for the deck height for a 924 block. By deck height I mean the distance between the centerline of the main bearings and the top of the cylinder block.
I have looked at almost all of the post that came up when I searched the term "Deck and Height", but none of them address this value. I have also looked in the Technical Specifications for the 924 models 78 -85.
Any help would be appreciated.
Thanks,
Tom _________________ Casper and Big Red, both 1980 NA
Black Bart, 1990 944 S2 Cab |
tomcooper
Posted: Thu Mar 01, 2007 11:42 pm Post subject: |
I can't believe that after 57 hits there isn't someone that can answer this question. I have found a lot of information, but the stock deck height seems to be a international secret.
-nick
Posted: Fri Mar 02, 2007 7:59 am Post subject: |
What is it you want the info for? If it's just for calculation, then you, or your machinist should be able to measure your own block pretty easily. If you're concerned about the deck being cut too much on your block, then you could probably get someone to measure the pan-to-deck distance on a known untouched block. In fact, the way the crank is bolted in, that number should be the same as the deck height you're after. _________________ 1980 931S
1991 964 C4 Cabriolet |
tomcooper
Posted: Fri Mar 02, 2007 10:12 am Post subject: |
Nick,
We have calculated a number, now we would like to know how it compares to the publish figure. We are trying to determine why a particular configuration does not work on the block I have. It maybe that I just have a odd ball block, or there maybe a mistake in the machining of one of the components, figuring out which is going to be the trick.
Posted: Fri Mar 02, 2007 11:33 am Post subject: |
This is not your average measurement covered in haynes... you will probably need the factory manual...
that being said, you will need to take into account if your block has been previously decked or had oversized bearings put in...
Leadfoot _________________ 1981 ROW 924 Turbo -
Posted: Fri Mar 02, 2007 1:54 pm Post subject: |
I couldn't find in the the 924 Turbo factory manual. _________________ White 87 924S "Ghost"
tomcooper
Posted: Fri Mar 02, 2007 9:14 pm Post subject: |
Paul,
Thanks for looking. It's not in the set of manuals I have either. I am not sure were else to go, that's why I asked here. I have a spare block that I will have cross checked and if the numbers are anywhere close, I'll publish them here. With the current weather here in the midwest that may take some time.
Martijnus
Posted: Sat Mar 03, 2007 9:07 am Post subject: |
stupid question from here, but what I'd do is measure the distance from the big-end to the deck in TDC and BDC, you know the stroke (i hope;) ) and with these measurements and one easy calculation you've got your actual deck height, not depending on the possibility that something has been modified like a deck grind or something.
The question is... how accurate can you measure  _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
tomcooper
Posted: Sat Mar 03, 2007 10:36 am Post subject: |
No, the question is what is the factory specification. We know what deck height we have measured, calculating the compression ratio using that value results in a ratio of greater than 11.5 to 1. Can you say racing fuel?
This is supposed to be a street engine that runs in a daily driver. Don't think that I can afford to pour $5.00 per gallon fuel in it.
Raceboy
Posted: Sun Mar 04, 2007 6:05 am Post subject: |
| tomcooper wrote: | Don't think that I can afford to pour $5.00 per gallon fuel in it.
Tom |
We have app. 5$ per gallon for 98 (93 for you) fuel prices here, so don't complain!  _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Martijnus
Posted: Wed Mar 07, 2007 10:07 am Post subject: |
euh... a gallon is about 4 litres? (3.7 says wikipedia)
here the prices were 1,50 EUR for one liter.
Times 4 is 6 euro's for 4 litres or one gallon.
6 euro's is about 8-10$ as far as I know... so that's twice the price.... for regular gasoline! (98 octane in my case)
(euh... wait...is racing fuel 98 octane at your side of the pond?)... _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
