GeorgeV
Joined: 14 Mar 2010 Posts: 306 Location: Brisbane, Australia
McGyver
Joined: 24 Feb 2009 Posts: 354 Location: Jelenia Gora - Poland
Posted: Tue Jun 11, 2013 5:07 am Post subject: |
All what I got together
1.
6Jx15" ET36 - ( 911.361.023.44 6.5kg) - Front
7Jx15" ET23 - ( 911.361.023.54 6,9kg) - Rear
Tires Pirelli P6 195/65/R15 91T on all 4
No spacers at all.
2.
U 911 361 022 00 Perforated disc wheel steel 5 1/2J x 15, ET53 9kg
KpZ number is 6155A - 5 ½ x 15 ET=53
Goodyear Ultrasnow 195/65/R15 on all 4
No spacers at all
3.
996 or Boxster - Cup 3 (That they called it in Porsche shop)
7" - 996.362.124.00 - ET 55 - 8.4kg - Front
8,5" - 996.362.126.05 - ET 50 - 9.1kg - Rear
Added just 8mm spacer at rear (I will try also with 5mm when I get one) - without standard 21mm rear spacer!!
Tires are Pirelli P6000 205/50/R17 Front and 225/45/R17 Rear. _________________ 931 82' - 5000km after full engine rebuild
www.mauser98k.internetdsl.pl - if someone like german rifles (English version avalible) |
GeorgeV
McGyver
Posted: Wed Jun 12, 2013 12:14 am Post subject: |
I don't have any problems I saw many 931's with 16" (6/7") wheels on them and even 924's with 205 and 225 tires. I choose this wheels because I saw one 931S1 here with Boxster S model (7" an 8,5" booth 17" and they fit)... than I found cheap this 996 wheels for sale so I wanted to try them)... I don't like that CC I had before... I made right now about 40km on that 17" without any problems at all. Car run ok on corners and in straight way. It runs good and fast like before Only thing was that I had to add spacers at rear (original 21mm was missing somewhere in previous owners - I think that one who put that Cookie Cutters on this car, which don't fit too good (especially front was little to much out from front fenders).
If it is important I think it could...
I have stock springs in front with yellow regulated Koni. and Bilstein B6 on rear.
951 26,8mm front sway-bar and stock 931 rear. I have standard brakes
Everything works and looks great I think that 17" wheels are best for 931 or that Boxster S... _________________ 931 82' - 5000km after full engine rebuild
GeorgeV
McGyver
Posted: Wed Jun 12, 2013 7:22 pm Post subject: |
I used to don't have power steering in 924's so it's not a problem. Actually I saw many 924's with 205 or even 215 on fron without power stering and all was fine Maybe for womans could be to heavy... but for most men's is ok. _________________ 931 82' - 5000km after full engine rebuild
GeorgeV
Posted: Thu Jun 13, 2013 9:17 am Post subject: |
McGyver wrote: | I used to don't have power steering in 924's so it's not a problem. Actually I saw many 924's with 205 or even 215 on fron without power stering and all was fine Maybe for womans could be to heavy... but for most men's is ok. |
Thanks McGyver. _________________ 1981 932 with mods:
http://www.924board.org/viewtopic.php?t=37921 |
frankg
Posted: Thu Jun 13, 2013 5:58 pm Post subject: |
This is actually a 931 not 951, just has a body kit on. It has the original 951 D90s on with 205/225 combination looks great and steering isnt any heavier than standard after all the only difference is standard is 205 all round so only the rear tires are wider. _________________ Life is about living, we all leave soon enough. |
vandale
Posted: Sat Jul 27, 2013 6:24 pm Post subject: |
Hi, new to the forum and 924 ownership.
Currently tidying the car up for compliance, put some motoform 16x8's on. Chrome doesn't look great on red in my opinion so they will get powder coated a dark colour when I panel and paint the whole car.
Thanks
[/img] |
joejax
Joined: 02 Dec 2009 Posts: 919 Location: Jacksonville,FLA,USA
Posted: Sat Aug 03, 2013 11:05 am Post subject: |
ideola wrote: |
Forged Club Sport 7Jx16 on all four corners, satin black powder coat.
Toyo R888 (205/55R16 up front, 225/50R16 out back).
Early offset alu front control arms from an 86 951 with 968 hubs and spindles
Early offset alu trailing arms from an 87 924S with no spacers
Ride height lowered by approximately 1" (~6" clearance from concrete to bottom of rocker).
I love it! Sure do miss mine. Don't know if 'themadelectrician' is really mad or what, having seller's remorse... _________________ I got nothin'
Uhhh...you got any pics? |
sciroccosteve
Joined: 16 Apr 2012 Posts: 215 Location: Rochester, NY
Posted: Wed Apr 30, 2014 9:42 am Post subject: |
where can a boy get his hands on the 4x108 Fuchs? _________________ 1979 924
2000 V6 Passat
"Let the fools have their tar tar sauce."
C. Montgomery Burns |
serzas
Joined: 20 Nov 2012 Posts: 52 Location: Lithuania, Europe
Posted: Sun May 04, 2014 7:31 pm Post subject: |
r18 RH turbo replica's with original suspension setup _________________ Porsche 931 1980 widebody CS / no, stock again
ex Porsche 944 1984 turbo look
ex Porsche 924 1982
ex Porsche 924 1978 |
ViktorTsoi
Posted: Sat Jun 21, 2014 10:51 am Post subject: Cookie Cutters |
Cookie cutters with 215/60R15 Michellen Pilot Sports. I believe they are the 53mm offset and 7 inches wide. Sticks out in the front quite a ways with about -0.5 degrees of camber. After running them for a couple hundred miles the fender lips have chewed up the tread on the outside of the tire a bit. _________________ 1978 924 -parts car
1982 924 -sold
1985 944 |
racetherat
Joined: 29 Mar 2013 Posts: 15 Location: Sydney, Australia
Posted: Mon Sep 01, 2014 9:53 pm Post subject: |
Teledials:
front - 15x6" 195/65/15 ET 36mm, part number 911.361.023.46
rear 15x7" 215/60/15 ET 23mm, still has the factory spacer, part number 951.362.104.00
Simple bolt on to the 931. _________________ 931 EFI/supercharged |
