Things to look out for...
Jimaras
PostPosted: Mon Jan 22, 2007 1:07 am    Post subject: Things to look out for... Reply with quote
Hello everyone! I am from Cyprus and i have accidentally found a 924 of 1979 for sale for 2.500 CYP (about 2.200 English Pounds). It has its MOT passed until 2008 and when i started the engine it sounded great. The interior needs some work to be done. I will take it to a mechanic to check it out to see if it is worth it. Can you guys tell whet what to look for ? I mean...common problems that it may have like a bad clutch disk or something ? Problems that these cars usually have. Thank you! Great forum and i hope i will be soon a part of your community.
PostPosted: Mon Jan 22, 2007 1:29 am    Post subject: Reply with quote
wash the car with a heavy stream of water and leave someone inside the car to look for leaks, esp around where the battery sits.
3 928s,
Neil924
PostPosted: Mon Jan 22, 2007 1:48 am    Post subject: Reply with quote
I sent you a message.
germ924
PostPosted: Tue Jan 23, 2007 2:20 pm    Post subject: neil924 is your 924 for sale Reply with quote
the image you have for an avatar. do you have it listed on ebay
check out this link http://cgi.ebay.com/ebaymotors/1977-Porsche-924-Euro-w-Carrera-GT-body-125k-KMS_W0QQitemZ160077212109QQihZ006QQcategoryZ6431QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
[url][/url]
JB 924
PostPosted: Tue Jan 23, 2007 2:39 pm    Post subject: Reply with quote
Yep, that's his.
Mike924
PostPosted: Tue Jan 23, 2007 6:09 pm    Post subject: Reply with quote
Are cars expensive on Cyprus, Jim?
£2200 would be quite a high price, even in England.
I'd work on getting the price down for a start.
Generally these cars are pretty reliable. The only common faults being leaks (as Lizard states), and a few fuel and electrical gremlins that can be readily sorted with a bit of patience. Synchromesh on second gear can be a bit iffy, but people learn to live with that.
Good luck.
PostPosted: Tue Jan 23, 2007 7:25 pm    Post subject: Reply with quote
rusty gastank check the filler..good luck great year for the 924 was 79.
