Removing the side mirror....
79porsche
PostPosted: Sat Jan 20, 2007 7:36 am    Post subject: Removing the side mirror.... Reply with quote
I need to replace one of the side mirrors and I have the door panel off. How is the mirror attached?
1979 Porsche 924 N/A
PostPosted: Sat Jan 20, 2007 8:13 am    Post subject: Reply with quote
From the pic here, it looks like two self tapping screws (#4).
Good luck,
rasta
Ozzie
PostPosted: Sat Jan 20, 2007 8:54 am    Post subject: Reply with quote
Rotate the mirror fwd and remove allen screw 19.
The rest is easy.
Its AUTO and its BLACK
Montego Black on black/red
Mike924
PostPosted: Mon Jan 22, 2007 6:28 pm    Post subject: Reply with quote
...unless the barrel-shaped 'nut' on the inside of the door skin is rusted solid to bolt 19; then you're screwed. I speak from experience!
(PS it might be different for non-electric mirrors.)
PostPosted: Tue Jan 23, 2007 3:19 am    Post subject: Reply with quote
So what'd you do, Mike? Are you talking about 5 in the illustration?
CBass
PostPosted: Tue Jan 23, 2007 11:51 am    Post subject: Reply with quote
I rotated until the screw snapped. Then I pulled out the power mirrror, associated wiring and was glad to be rid of it. Welded up the holes, filled the gouges in the paint... Have yet to get around to drilling the holes for my new mirror.
PostPosted: Tue Jan 23, 2007 1:07 pm    Post subject: Reply with quote
I had to once use a drill and I managed to drill out the head
of said screw 19 beacuse the allen head pattern rounded
out. the allen wrench wouldnt grab anymore.
Mike924
PostPosted: Tue Jan 23, 2007 5:58 pm    Post subject: Reply with quote
Well..., in my case, I abandonned the idea of removing the mirrors!
Your picture shows the manual adjustment mirrors, which are probably the ones on 79Porsche's ...er... '79 Porsche.
The power mirrors are slightly different and a real PITA (as the other posters have testified) once water runs down the Allen-head bolt and rusts the 'nut' (which I don't think is represented in the illustation).
