Odometer FIX. HOW and WHAT to do?
SamTLS03
PostPosted: Tue Jan 23, 2007 10:51 am    Post subject: Odometer FIX. HOW and WHAT to do? Reply with quote
Can someone point me in the right direction here? I'm a noob to 924board.org and I need some help. I recently purchased a 87' 924S and the Odometer is stuck.
I've heard that the odometer will stop working when you reset the trip while moving . I find this strange but true . So now I need to fix it.
How and where do I start?
I appreciate your help guys as I know you'll help direct me.
PostPosted: Tue Jan 23, 2007 11:22 am    Post subject: Reply with quote
Here.
Try the search function at the top of the page, it works great.
Welcome to the Board,
rasta
PostPosted: Tue Jan 23, 2007 1:36 pm    Post subject: Reply with quote
In addition to the plastic gear, I had to deal with the metal wheel that's buried deeper in, on the same shaft.
...a little more detail on it here -
http://www.924board.org/viewtopic.php?t=5998
The drill-running-in-reverse-trick mentioned there can be used to test it before reinstalling in the car.
SamTLS03
PostPosted: Wed Jan 24, 2007 11:14 am    Post subject: Reply with quote
Smoothie. You're a gentleman and a scholar. Thank you very very much. Sounds like I'm not the only one conquering this problem.
If anyone has any additional tips, please let me know!
PostPosted: Tue Jan 23, 2007 12:22 pm Post subject:
Here.
rasta
Rasta. You really are Rasta. Thanks man. I think with all this info i should be able to tackle the problem.
Any reccomendations on where to get the broken gears and replacement gauge bulbs? Just a curious shot at it.
Thanks guys!!
You guys are saving me tons of time.
1987 Porsche 924S Can-Can Red
Their are things Porsche can do that no one else can....
!tom
PostPosted: Wed Jan 24, 2007 12:30 pm    Post subject: Reply with quote
I picked up some bulbs at my local Canadian Tire. Since we don't know where you're from (updating your location in your profile helps) I don't know how useful that is. Any automotive store should have them though; the bulbs are common.
Sorry I can't help you on the gears though. I repaired mine myself.
78 924 NA
5-lug
