johnrizo
Joined: 02 Jan 2007 Posts: 28 Location: Adelaide, Australia
Posted: Tue Jan 09, 2007 7:32 pm Post subject: under tray...keep it ditch it? |
hi
ive got a 1981 924
im wondering whether i should remove my under tray.
whats it there for?
will the car run cooler?
is it there for a reason?
thanks
regards
john |
Khal
Posted: Tue Jan 09, 2007 7:54 pm Post subject: Re: under tray...keep it ditch it? |
| johnrizo wrote: | | im wondering whether i should remove my under tray. |
No.
| johnrizo wrote: | | whats it there for? |
To protect the engine and to direct air flow.
| johnrizo wrote: | | will the car run cooler? |
Yes.
| johnrizo wrote: | | is it there for a reason? |
| Khal wrote: | | To protect the engine and to direct air flow. |
You really need to learn to search before asking questions, johnrizo. We don't mind answering but many of these question have been covered ad nauseum... _________________ '80 924 Turbo |
D Hook
Posted: Tue Jan 09, 2007 9:14 pm Post subject: |
Pull the tray off and leave it off until you get the car running better. Otherwise, you'll be pulling off every day or so. Khal is correct; it's there for a reason. However, you'll get very frustrated quickly with the repair work so just leave it off for now.
Might also want to put your year and model in your sig line so everyone knows what you've got each time you post a question. Makes it easier for everyone and you get the right advice for your model year.
Welcome to the board and good luck with the new purchase. There is alot of knowledge on the board. Be sure you have a Haynes or some kind of repair manual. _________________ '80 924 n/a SOLD |
dgz924s
Posted: Tue Jan 09, 2007 9:36 pm Post subject: |
The belly pan also help divert air back instead of up through the engine bay. Air under being forced upwards cause handling issues. _________________ Dal Glassinger |
Nobbi
Posted: Wed Jan 10, 2007 1:56 am Post subject: |
I leave it in place for one reason, i am driving without timing belt cover
( to keep an eye on it) and that pan prevents against debris flying into my timing belt.
Nobbi  |
