he's at it again
PostPosted: Tue Dec 12, 2006 8:39 am    Post subject: he's at it again Reply with quote
http://forums.rennlist.com/rennforums/showthread.php?p=3663273#post3663273
Tim is having the same issues with the 944 that he had with the 924, now he is thinking about a 928. Maybe someone should suggest a 911 as there engine is in the back and they dont have a rear hatch for the fumes to leak in!
3 928s,
PostPosted: Tue Dec 12, 2006 8:41 am    Post subject: Reply with quote
Hmm, I think a mid-60's Ferrari would be a perfect fit for Timmah's "inclinations" (and no headaches, either)!
Min
PostPosted: Tue Dec 12, 2006 8:53 am    Post subject: Reply with quote
why doesn't someone just tell him to turn on the interior fan in the low speed setting so that it pressurizes the cabin?
Min
PostPosted: Tue Dec 12, 2006 8:57 am    Post subject: Reply with quote
Because he would say "I can't do that, I stepped on it and broke it while I had it out for lubrication. Besides, how would that do anything, the smell is coming from the rear? Ow, my head. OW!"
r
PostPosted: Tue Dec 12, 2006 9:26 am    Post subject: Reply with quote
damn...the guy is getting wealthier every year(924/944/928)....wtf...maby he will buy a plane next ....
StienbargerR
PostPosted: Tue Dec 12, 2006 1:33 pm    Post subject: Reply with quote
he's probly just got his damn radio too loud. That, or he needs glasses.
Ryan
1978 924 NA
-250lb lowering springs, Euro Pistons
PostPosted: Tue Dec 12, 2006 1:55 pm    Post subject: Reply with quote
Well at least it appears he finished a front service....
StienbargerR
PostPosted: Tue Dec 12, 2006 2:00 pm    Post subject: Reply with quote
Min, I bet your right about the fan thing. I think its too much of a coincidence. Maybe no one ever told him you should always have the fan on at least a little.
Ryan
1978 924 NA
Mike924
PostPosted: Tue Dec 12, 2006 6:01 pm    Post subject: Reply with quote
He sold his 924 and bought a 944, and yet his name on rennlist is yummybud( )924...
One mixed-up dude.
Also, I'd like to know what student job he's got that pays for a 928. Last I heard, he was working in a grocery store.
1985 Porsche 924 'Lux', Kalahari Beige (my ex)
1993 Porsche 968 Coupe, Midnight Blue, 6 spd
'There is no substitute for a little grease under your fingernails.' - Chrenan, 924board.org
Ozzie
PostPosted: Tue Dec 12, 2006 7:06 pm    Post subject: Reply with quote
His underwear is 2 sizes too small.
Its AUTO and its BLACK
Montego Black on black/red
timstar92404
PostPosted: Tue Dec 12, 2006 7:26 pm    Post subject: Reply with quote
haha, I don't work at a grocery store, that was a long time ago. I now do sales/ how much I make depends on how much I sell. Right now because it's close to christmas I make a lot of money but I probably will make much less after christmas.
actually about the fan, the fan on my car doesn't even fully turn off, when the car is running hot heatcomes out of the heating vents even when it is turned to zero, I was told that this happens when the heater system fails. Also the airconditioning doesn't work (related to this). Before I changed by belts and pump the air conditioning was blowing ice cold so it just broke down after sitting or something.
Tomorrow I'm getting the old carbon monoxide tester out and will put it in my car when I drive to work. I already used foam tape all over the top hatch so it looks like it seals tight now, I was even considering duct taping the entire hatch from the inside.
and it's not only me you can do a search on rennlist and there are tons of threads about fumes getting in 944s and a lot of other people have replaced the seals etc and still can't fix it.
I personally can't smell anything inside the car except just an old car smell same as my 924 but with the 924 I had CO inside as shown by the detector.
anyways I don't really care anymore. It's just a car, I can always sell it. I wouldn't sell it for less than 4500 though, I just did the belts, water pump, seals and paid 800 for new tires.
78 924 sold.
85.5 944
timstar92404
PostPosted: Tue Dec 12, 2006 7:32 pm    Post subject: Reply with quote
I'll try the fan thing, tomorrow. The fan is stuck on hot so when the engine warms up it will blow hot air and it gets uncomforably hot inside the car so I just turn off the heat (even though it still blows heat out a little). I haven't had time to see what broke with the heating system, because it's apparently stuck on the hot setting.
78 924 sold.
85.5 944
PostPosted: Tue Dec 12, 2006 8:03 pm    Post subject: Reply with quote
dude you might be too sensible to these fumes...because to be honest all porsches that i have been in leak a little inside(including a 924S4)...but i'm not feeling deranged by this...
timstar92404
PostPosted: Tue Dec 12, 2006 8:46 pm    Post subject: Reply with quote
yeah you could be right, I also thought maybe I'm just really sensitive to the fumes.
with my 924 the highest reading I got with the windows closed was like 70 ppm, it should be 0 but that 50-70 ppm isn't crazy high CO levels but I guess it can be enough to cause headaches /dizziness.
also I want to get the interior of my car professionally cleaned, it has a old car smell to it and someone mentioned that maybe there is mold in the car.
I'm going to use my CO tester tomorrow when driving to see what it reads.
78 924 sold.
85.5 944
Mavfan
PostPosted: Fri Dec 15, 2006 1:23 am    Post subject: Reply with quote
about the heater always being on, did you check the clips underneath the dash to see if they had broken?
go to the bottom of the page: http://clarks-garage.com/shop-manual/hvac-01.htm
Black 1988 924S SE
Red 1985.5 944
http://mavfan72.tripod.com/
http://www.cardomain.com/id/mavfan
Video:
http://video.google.com/videoplay?docid=-5193982457901018136
