Dash Repair
PostPosted: Tue Aug 14, 2012 12:08 am    Post subject: Dash Repair Reply with quote
Being out here in sun country cars are generally rust free, but the sun damage can be horrendous. This is a summary of how I repaired my dash.
First the condition when I started:
http://i1180.photobucket.com/albums/x413/MikeJinCO/Dash%20and%20Interior%20restoration%20Porsche%20924/CopyofDSC00803.jpg
After some research I decided to use some easily sandable plastic bumber epoxy repair filler. I got mine, Maxim by Evercoat from Eastwood, 3M has a similar product. It is a two part epoxy in a caulking gun and takes a high pressure gun to get it thru the mixing tube. For my purposes it worked better to just use a regular caulk gun and mix and apply it with a tongue depressor. I first cut the gaps wider to give the epoxy more area to get a good bite per the directions.
When applied and sanded it came out like this, 80 and 100 grit sandpaper was all I used.
I then decided since the top vinyl was extremely brittle I should give it a new surface so I took some of my epoxy and 2oz fiberglass and applied it. I've worked with this for 30 years on curved surfaces and it would be very difficult to do a very good job on the more curved front surface.
Then since the surface had lost most of its texture I went to the truck bedliner spray and gave it a good shot which works well, but appears somewhat damageable.
I then painted the finished surface with SEM Graphite interior plastic paint as with my recovered seats the graphite works better than black.
So it is definitely not perfect, I didn't try to fill the warping up near the defrost vents, but it does look pretty good, probably a 6 or 7 out of 10. Will it hold up? Who knows? A good vinyl or leather recovering would be much better, but I'd rather spend that money on some HC pistons.
Mike
'77 924
cricketdesigns.com
PostPosted: Tue Aug 14, 2012 2:05 am    Post subject: Reply with quote
Looks fantastic.
PostPosted: Tue Aug 14, 2012 8:02 pm    Post subject: Reply with quote
+ 1!!
PostPosted: Tue Aug 14, 2012 8:03 pm    Post subject: Reply with quote
^ + 1!!
PostPosted: Tue Aug 14, 2012 11:11 pm    Post subject: Reply with quote
Thanks, but it actually looks better in pictures than up close.
Mike
'77 924
cricketdesigns.com
PostPosted: Thu Aug 16, 2012 5:27 am    Post subject: Reply with quote
Still looks as good, if not better, as the pic of my $400 so called professional job, that was in better starting condition.
Great job modest Mike.
Allan @ DTA wrote:
ThomasJoseph315
Guest
PostPosted: Wed Jun 26, 2013 2:04 pm    Post subject: Reply with quote
Wow,.. nice! +10
sbarc
PostPosted: Wed Jun 26, 2013 2:17 pm    Post subject: Reply with quote
A very effective and inexpenisve repair job.
The other option is to send your dash to www.justdashes.comand get them to do it....but I think that costs about $1000 to restoore a dash.
1981 931 (Canadian car)
1981 931 (US car)
1990 928GT (ROW car)
1991 Toyota MR2
1989 Toyota MR2 Super Charged
1985 Toyota Supra
1973 Triumph GT6
1971 Opel GT
ThomasJoseph315
Guest
PostPosted: Thu Feb 27, 2014 9:44 pm    Post subject: Reply with quote
^ Just dashes is like 20 mins from me
txjake
PostPosted: Fri Feb 28, 2014 2:01 am    Post subject: Reply with quote
nice. I might try that method next winter on mine...
1978 924, aka The Red Rocker
PostPosted: Tue Oct 07, 2014 4:58 am    Post subject: Reply with quote
Well, x years later some of the cracks have opened up again. The places I put the fibeerglass on are fine, but 2 or the front ones have opened up again.
Mike
'77 924
cricketdesigns.com
edredas
PostPosted: Tue Oct 07, 2014 6:37 am    Post subject: Reply with quote
Sorry to hear that. The same has happened to the two dashes that I fiberglassed as well. I've been thinking about making a kick-starter to fund making us some solid fiberglass dashes that will never crack.
'87 924S -Red, 300hp 951 swap
'87 924S -Red, New Project
'87 924S -White, Automatic
'88 924S -Red, Daily Driver, Bone stock
'93 Mx6 -White, Megan Racing suspension
PostPosted: Tue Oct 07, 2014 7:53 am    Post subject: Reply with quote
Where I fiberglassed it is fine, I used some 2oz fiberglass and WEST epoxy. Heavier glass wouldn't drape over the curves as well as it is less flexible. With as many curves and corners the dash has it would have to be set up for either vacuum bagging if using cloth or probably a chopper gun for fiberglass. I don't know if I could get any matte to conform to the shape as I really haven't used it that much . We are taking off for the winter to South America in November but would like to work on it in the spring.
Mike
'77 924
cricketdesigns.com
v8carreragts
PostPosted: Sat Oct 11, 2014 12:20 pm    Post subject: Reply with quote
Here's mine
I filled in the cracks with structural adhesive )3m Automix 08115) then used a dash cap and bonded that on with the same structural adhesive.
84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Dodge Charger R/T AWD HEMI
2013 Chevy Cruze
PostPosted: Sun Nov 02, 2014 12:25 pm    Post subject: Reply with quote
had you thought of a loose weave like woven rovings? something that will bunch up where you need it to and expand in other areas... then apply a body filler over the top.
I normally get into my curves by tearing light mat and blending the edges, just have to make sure the mat has plenty of resin to wet out properly.
Post new topic   Reply to topic    924Board.org Forum Index -> How-To All times are GMT + 11 Hours
