steering rack issues
mcadam1121
PostPosted: Sun Oct 10, 2010 9:30 am    Post subject: steering rack issues Reply with quote
Has any one had problems with the location of the steering rack. Mine is in the way of my oil pan on my motor and I was wondering if any of you guys have had problems. Another issue is the linkage between the steering collum and the rack it is routed in a horrible possision have any of you guys had to reroute the linkage and if so how did you do it
The Ginger
77 porsche 924 Martini
PostPosted: Sun Oct 10, 2010 2:33 pm    Post subject: Reply with quote
Most modify the oil pan to clear the rack and crossmember.
The position of the rack is important for the handling.
A question for the suspension guru's, can you swap the uprights and use a "normal" rear steer Rabbit rack and not have too many issues with the suspension and handling?
